Results 1 to 7 of 7
Reload Thread: are you useing a jbl1200 amp
    palikt's Avatar
    palikt is offline Senior VIP Member
    Mar 2003
    ar
    350
    if you are useing a jbl 1200 amp.what size and kind of use are you useing,because i need to get one
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    Re: are you useing a jbl1200 amp
    what size and what kind of what?!.......
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    palikt's Avatar
    Mar 2003
    ar
    350
    i am talking about the fuse.it calls for a 120 amp fuse. but i have a inline fuse holder and i was told the bestes one you can get is 80. then they said ill have to upgrade to a anl fuse
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    no, an 80 amp will be OK....but if the fuse blow a lot...then u should upgrade. But, u might be able to get by with 80, considering that the amp doesn't run consistently at MAX current draw. peace
    NG
    nG - BSEE
    palikt's Avatar
    Mar 2003
    ar
    350
    i nevere max my stuff out because i dont want to mess it up.pluse my crossover will be doin alot to hel p the amp out
    palikt's Avatar
    Mar 2003
    ar
    350
    ok, got it all going. now should i run a power cable for the crossover or should i just get a inline fuse and tap in to the amps power and if so what size fuse should i use??? the vrossover is a kicker x3i
    MikeofTulsa's Avatar
    MikeofTulsa is online now The one and Only!
    Feb 2002
    Tulsa, OK
    21,255
    1 Post(s)
    309 Post(s)
    i'd say seperate power wire for it
