Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Reload Thread: New sub sounds horrible. Is it time for a new amp?
  1. #16
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    Re: New sub sounds horrible. Is it time for a new amp?
    turn the frequency on the amp to 80-100. And you mean hz, not db.
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
  2. #17
    KidThump's Avatar
    KidThump is offline V.I.P
    Oct 2006
    Georgia
    1,845
    its prolly the box....
    01 Jeep Grand Cherokee Laredo
    JVC KD-S26- AP 100.2-AP 1500d
  3. #18
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    if you can, make a video with sound and play a low song.
    REFS:
  4. #19
    Rich B's Avatar
    Rich B is offline CarAudio.com Veteran
    Oct 2006
    *under the rainbow*
    6,504
    14
    235 Post(s)
    The easy answer is that your amp is probably fine.
    You must have a box that suits the specs of your new sub.
    If its not right it will sound like crap.
  5. #20
    tcguy85's Avatar
    tcguy85 is offline CarAudio.com Veteran
    Feb 2007
    Hyde Park, NY
    33
    3,527
    some subs just play certain frequencies better. maybe the new one just ***** at playing the higher frequencies. i know when i went from my old style type r to the treo ssi that i have now i gained a whole lot of bottom end over the type r. some subs just excel in the lows some excel in the upper bass region.
    07 Scion tC: 880PRS, ID OEM 6.5" mids, Seas neo alum tweets, DD S4 and DD C2a amps, Dayton Ref H.O. 10(.7net, tuned to 30hz)
    HT: Samsung PN58B560 - 80gig PS3 - Yamaha RX-V2500 - Infinity Alpha 50 mains - Alpha center - Harmon Kardon HKB6 rears, Epik Sentinel & ED eQ.2.
  6. #21
    brynm's Avatar
    brynm is offline CarAudio.com Elite
    Mar 2006
    Saskatchewan, Canada
    1,016
    106 Post(s)
    Quote Originally Posted by Sonicpilz View Post
    I have both filters set at 125hz. The box is sealed and is approx 1sq ft in size. The same box AND amp were used for both speakers. The smaller speaker was wired at 4ohms but this larger sub is wired at 1ohm.
    The MTX is a mono amp but it has 4 terminals for convenience. I have the speaker wired in parallel and I'm using the + from one "channel" and the - from the other "channel".
    I can listen to a song and my mid-high is NO louder than my door speakers. Literally you wouldn't even think I had a sub in here. Then when it hits the mid-low it sounds "ok". But when it hits the REALLY low notes (not in normal music) it almost throws the sub out of my box and distorts horribly.
    Did only one other person catch this? If you set your high pass filter (HPF) and low pass filter (LPF) at 125 Hz. I imagine it would sound bad, it's a sealed box sow set your HPF at the lowest value you can and your HPF at 80-100 and play with it to see where it sounds best.
    With both filters set at the same number it'll play that frequency louder than any other frequency. The further away from that frequencey you get the more it's filtered out.
    Current: Pioneer AVH-P8400BH, Hertz HSK165 comps on a MBQ DSC4125, pair of Clarion SSW1001 10" on a MBQ DSC2000.1
    Kickers: SX600.2, SX1250.1, SXRC
    MB Quart: DSC4125, DSC2000.1
    12" SI Mag V3 @ 1 ohm, 2-10" Clarion SSW1000
    Quote Originally Posted by iceteebone View Post
    I've only been caught once. I guess it wasn't smart to be fornicating in a tent display at Dick's Sporting Goods on black Friday
    Quote Originally Posted by Loud3 View Post
    we iz teh curaoutioz.coms.
    we is no kan speel
  7. #22
    jkulysses's Avatar
    jkulysses is offline Senior VIP Member
    Aug 2007
    Oregon
    354
    The 1501d is also only stable at 2ohm. I think I read somewhere they can be modded to run at 1ohm. I have th 801d and this is the info I was given. Here's a link to the owners manual. http://www.mtx.com/caraudio/archive/...801D_1501D.pdf
    I have my pioneer deck at like 80hz for the sub output and I don't have the freq on the amp turned all the way up but pretty close. I don't think your amp is the problem. I think it's a combo of wrong settings on amp and deck and probably not the right box.
  8. #23
    jkulysses's Avatar
    Aug 2007
    Oregon
    354
    After quickly glanzing at the specs for that sub it's rec. enclosure is .5 to 1.0 cu ft so the box shouldn't be the problem here cause you said it's in 1.0 correct.
  9. #24
    Sonicpilz's Avatar
    Sonicpilz is offline Junior Member
    Oct 2007
    Greenville, SC
    14
    Ok guys I just confirmed this crap. I grabbed my old Orion (only 500rms) and threw it back in there. Man....that thing will rattle the brain!!!
    I had the truck parked in the drive way and it rattled the windows on the house. With the Pioneer you can literally stand beside the truck and hear nothing. Not even the doors rattle or anything!!!!
    Its got to be the sub. But WTF!!!!!! I heard all this hype on how freaking loud and amazing these Pioneers were. For god sakes it can handle double the power. Did I just get a ****** one or something???
  10. #25
    kross's Avatar
    kross is offline CarAudio.com Elite
    Jul 2007
    Seattle, WA
    764
    Since you bought it new from a local dealer, take it to them, and let them fix it. That's part of what you're paying for, is their customer service.
    Thou hath not so much brain as ear wax.
  11. #26
    Haden's Avatar
    Haden is offline Dr Gibbles
    Sep 2007
    Here
    595
    almost sounds like what happened to mine--turns out i had a broken tinsel lead
    Truck- Dodge Ram
    HU- Kenwood KVT-717DVD
    Amp- MTX 1501D
    Subs- Dual MTX 8000s
    Refs- JT1979, nbudros
    MTX TE1501D FOR SALE PM ME
    cheese
