Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Reload Thread: kicker kx2500.1 going in and out of protect
  1. #16
    aaron7114's Avatar
    aaron7114 is offline CarAudio.com Elite
    May 2006
    Arkansas
    1,707
    Re: kicker kx2500.1 going in and out of protect
    I'm runnin my kx2500 off a regular cheap everstart battery under the hood....120 amp alt....and a kinetik 2400 in the back. It hasn't shut off since I got my kinetik until just the other day it started shutting off. I dont think its the amp though. I think the negative on my kinetik is loose....or my alt is about to go out. But I have a lifetime warranty on it.
    I'm running it at 1 ohm also.
    Headunit:
    JVC AVX2 (3.5" Screen)
    Mids and Highs:
    Kicker 6 1/2" door speakers
    Four 3 1/2" Kicker Speakers in the sub wall
    Subs:
    Two 2006 15" Kicker L7s
    Amps:
    Kicker KX120.2 for Mids and Highs
    Kicker KX2500.1 for Subs
    Box:
    8 Cube wall tuned to 50 hz for comp and 36 hz for daily.
    150.4 db @ 47 hz on TL with 3 day old subs. Done a 156.8 since then on Audiocontrol
    Refs: 1 Hugh Jass, k4rts, vitveet, pioneerpimp, Colt9699, caligirl2k
  2. #17
    IgnoreMe's Avatar
    IgnoreMe is offline I love 2 girls 1 cup
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    Quote Originally Posted by KnOkIn It 420 View Post
    Are they really that efficent?Also when u set the gain,what rms were u aiming for.
    you misunderstood me lol. what i meant was i have no voltage drops due to bad ground, corrosion etc etc. for example i have 14v at the battery, and at the power wire right before it goes into the amp power terminal i still hold 14v. thats what i meant by no voltage drops. i DO have voltage drops at the battery when its running, just like lakota says. there really isnt anyway to get around voltage drop with any amp thats rated at 2500w.
    my benchtest sheet says i have 2960 @ 2 ohms. so i wired down to 1 ohm and set my gains for 3000w.
    llllllllllllllll Educate yourself and help stop the ignorance.
    llllllllllllllll DEA Judge Francis L Young says...
    llllllllllllllll Designing a Ported Box
    refs: hazardous0388, snoopdan, karleon, thelow, freezeman_7, imtjnotu, Gebrochen, astroladespl, billabongcr , mustbenu , thunder9500 , 91ser, djdilliodon (6 times), stupify, milenko515, Zeuslicious, Bmoorman05, WaTTsLOk187, too dope 1904, nate2587, rbiele126, denalilvr
    Don't Blame Me. I Voted for Ron Paul.
    BluePoint Air Ratchet for sale...click me bitch
  3. #18
    scrappy's Avatar
    scrappy is offline CarAudio.com Elite
    May 2005
    nowhere
    525
    1 Post(s)
    [QUOTE=George
    my problem is this. i have read from many many people that this amp will run @ 1 ohm daily. so i purchased 2 dual 1 ohm bl's wired down to 1 ohm (they sit at 1 ohm, even though fi said they were supposedly .7 ohm). i can listen to music all day long with moderate power levels. my eclipse is set to max out at 65, and i can listen to it at about 60 and still have the amp play. as soon as i go up, the amp cuts in and out of protect very quickly..[/QUOTE]
    Sounds like your clipping the amp. It plays all the way up to 60 but not any higher? Thats only five clicks whats the big deal? Set your amp at about 3/4 volume
  4. #19
    IgnoreMe's Avatar
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    Quote Originally Posted by scrappy View Post
    because the amp is set a little conservatively anyhow. that 5 clicks makes enough of a noticeable difference. my 2 18's off this kicker are only a decent bit louder than my friends 15" xxx off a pa 3000db amp...now THATS sad.
    i am set up using 65/80. my cd5000 doesnt clip until volume 78/80
  5. #20
    redeldog1's Avatar
    redeldog1 is offline Senior VIP Member
    Jul 2005
    miami
    330
    2 Post(s)
    i have the exact same problem with my treo 75.4. treo claim my gains might be set to high.
  6. #21
    IgnoreMe's Avatar
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    here is some readings i got using my dmm to get A and V and solving for resistance
    35hz i am sitting @ 3.71 ohms
    40hz - 4.05 ohms
    45hz - 6.63 ohms
    50hz - 4.79 ohms
    55hz - 3.91 ohms
    60hz - 3.72 ohms
    so just going by these readings i dont get anywhere NEAR going under the rated minimum stable load of the amplifier. i dont know man, maybe im just a big gay?
  7. #22
    Lakota's Avatar
    Lakota is offline Doesn't Know $hit
    Feb 2005
    Louisville, KY
    30
    6,222
    Quote Originally Posted by George View Post
    40hz - 4.05 ohms
    45hz - 6.63 ohms
    50hz - 4.79 ohms
    55hz - 3.91 ohms
    60hz - 3.72 ohms
    Did you use an ammeter as well as a dmm? V=IR?
    Ben Hemp
    1992 GMC Sonoma Ext Cab NEW BUILD
    2008 MECA S1 KY State Champion, 151.0 dB
    2008 MECA S1 WorldChampion, 151.8 dB
    2010 MECA scores: 150.9 dB S2, 151.6 dB S3
    Refs: smd4life, Subst4nce, wccoug21, dacheatham, thegreatestpenn, jshak07
  8. #23
    IgnoreMe's Avatar
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    Quote Originally Posted by Lakota View Post
    no i used just my dmm. first i measured voltage with it. then i disconnected 1 wire and wired the dmm in series to get a current reading. this only lets me go up to 10 amps but from what i have read, the readings should be the same, save the coils warming up and making impedance higher once they do.
    then i did V/A and got resistance at each freq.
  9. #24
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    I answered your PEE EMS!!!
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  10. #25
    IgnoreMe's Avatar
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    Quote Originally Posted by ngsm13 View Post
    nG
    lol
