Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: DLS vs. Arc multichannel amps
  1. #16
    desertheat's Avatar
    desertheat is offline CarAudio.com Veteran
    Oct 2004
    Tempe, Az
    3,157
    Re: DLS vs. Arc multichannel amps
    DLS uses 12db/oct internally. Internal crossovers FTL...
    You can read the manual, that helps
    http://www.dls.se/files/172/2/Manual_A-amp06_eng.pdf
    And yeah, I am partial to DLS. best amps I have EVER used or worked with.
    www.garage1217.com is a good place to get raw leds & parts for custom vehicle lighting!
  2. #17
    genxx's Avatar
    genxx is offline Team JL Audio
    Mar 2007
    Oklahoma
    1,170
    Desertheat-He wants to run active-I now the set he is using has the DRT-25 which needs to be crossed over no lower than about 2.5khz and up. Looking at the manual it apppears there is a 3x mulitplier on the HP filter on the front channels bringing it to 1800hz and up. Is that correct. Which is not going to get work with the DRT-25 tweeter's. I would say they might play that low with a steeper slope but its risky.
    This from the manual on the A4
    The filter setup are as follows:
    Front:Lowpass (LP) 50 - 125 Hz Highpass (HP) 20 - 200 Hz alt 60 - 600 Hz (x 3 button)
    Rear: Lowpass (LP) 45 - 200 Hz alt. 90 - 400 Hz (x 2 button) Highpass (HP) 20 - 200 Hz
    The x2 and x3 buttons are used if you run a 2-way
    I am not pulling for either amp in particular. Can we help this guy out in what will get him active 2-way front off the amp x-overs.
    I will try and find the manual for the ARC.
    http://www.arcaudio.com/arc-05/pdf/xxk_amp.pdf
    The ARC and DLS are both at the top of the yep when it comes to quality.IMO I would no hesitate to run either one. I like them both. Excellent products.IMO
    2009 USACi Basic Consumer World Champion, '09 IASCA INAC 2nd Place, 2010 MECA Finals MODEX 4th, '10 OK MODEX State Champion--Addicted to Sound Quality
    '06 F250: JL-Zapco-Pioneer
    '08 Focus-Kenwood-Zapco-ID-Hertz
    Team JL Audio, Team RAAMmat, Team Advantage Audio, Team MSE, Team Zapco
  3. #18
    innsanes's Avatar
    innsanes is offline CarAudio.com Elite
    Sep 2006
    HB Cali
    1,378
    15 Post(s)
    thanks guys for taking the time to help me choose the correct amp for my set up needs. I was just looking at the internal parts on the DLS and surely looks well built and impressive. Is there really a night and day difference from running passive to running active? I know that running active, it will be difficult to tune and wanted to know if theres actually a significant gain in sound going active. thanks once again
    2016 e-Golf
    Dynaudio
    Sundown 1500D
    0/1 gauge setup
    15" IDMAX
