Results 1 to 4 of 4
Reload Thread: JBL BP amps - Stereo vs mono
    badazzDD's Avatar
    badazzDD is offline Senior VIP Member
    Sep 2002
    Texas
    33
    273
    Hey all. I have a question about the JBL BP series sub amps. I just want to know if they put out the same power in stereo and mono operation. The amp in question is the 1200.1 I have it wired in 2 ohm stereo. Will it put out the same 1200W as it does in 2 ohm mono? I have heard that it is the same. Just checking to make sure.
    tommyk90's Avatar
    tommyk90 is offline THE WHOLE THING!!!
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: JBL BP amps - Stereo vs mono
    Well, that amp is mono, so that is the only way you can have it wired. All of the power ratings at one channel, because the amp is bridged internally. You can't have it wired in stereo(i think ).
    Team Kicker (R.I.P.)
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
    2008 Bassrace 130-139.9 Regional and National Champion
    2006, 2007, 2009, 2010, 2012 and 2013 MECA Champion (S1, SR1, DB1, S2, S3, S4, S5)
    One DD 9510 powered by two Sundown SAZ-2500's
    Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
    Kicker wiring throughout.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    5,022
    1 Post(s)
    266 Post(s)
    Re: Re: JBL BP amps - Stereo vs mono
    You're right except that it's not bridged internally, there's nothing to bridge in a monoblock. The two outputs you're seeing are paralell to each other just inside the amp. Meaning if you hook a 4 ohm sub to each set of terminals it will see a two ohm load. There are 2 sets of terminals just for ease of wiring multiple speaker leads.
    '04 Chrysler Town & Country (it was cheap and I have a family)
    • HU: Stock - Scosche SLC-4
    • Comps: Lanzar Opti6c w/Opti400x4d
    • Rear fill: Stock
    • Sub: Lanzar Opti1232D 3cf 29hz w/Zed Opti1000.1d
    tommyk90's Avatar
    Oct 2002
    Chicago Heights, IL
    33
    16,641
    20
    1 Post(s)
    76 Post(s)
    Re: Re: Re: JBL BP amps - Stereo vs mono
    Well, that's what i meant. By being bridged internally it's just like bridging two channels of a 2-channel amp into one. It is not possible to get stereo out of a mono amp.
    Team Sundown
    Team Maxxsonics
    Team XS Power
    Team DD
    Team B2 Audio
    Team Mechman
