Results 1 to 11 of 11
Reload Thread: 4 subs and 2 amp wiring question
    Nov 2006
    Bradenton, FL
    32
    1,131
    Just bagged 4 15'' SPLX 15's to replace my Mofo's. They are Dual 2's. I'm wanting to throw at least 1000 watts to each of them, maybe a little more. My question is, I know they can be wired down to 1 or 4 ohms. And I'm about to buy two amps, and wire them down so each amp is playing at 1ohm. Can I do this? Or would I need two .5 or 2ohm stable amps? Thanks
    *Under Contruction*
    05' Explorer Limited
    HeadUnit: Alpine 9853
    Subs: (4) SoundStream SPLX 15's
    Mids/Highs: (6) 8" Eminence Alpha 8MR and (4) Pyramid TW46 Titanium Super Tweeters.
    Mids/Highs Amp: Kicker ZX650.4
    On Order:
    Enclosure: 16ft^3 CRX Style Enclosure (Pending Build)
    Sub Amp: WTB 4,000-6,000 watt Amp
    Frontstage Door Speakers: (2) B&C 6PEV13 6.5's
    Old Setup:
    http://www.caraudio.com/gallery/browseimages.php?do=member&imageuser=31662
    Prowler573's Avatar
    Prowler573 is offline R.I.P. Gossamer!!
    May 2005
    Northwest Louisiana
    45
    18,522
    Re: 4 subs and 2 amp wiring question
    Quote Originally Posted by Platestacker45 View Post
    You're not going to get a 1 Ohm or a 4 Ohm load out of a pair of DVC 2 Ohm drivers.
    Not gonna happen.
    Yup.
    Refs: [CA.com] [eBay.com]
    Platestacker45's Avatar
    Platestacker45 is offline 941
    Nov 2006
    Bradenton, FL
    32
    1,131
    Quote Originally Posted by Prowler573 View Post
    I have 4 of them, not two. Are you saying the only way to wire them is to wire each pair to each amp and run a .5 or 2ohm load on each amp?
    *Under Contruction*
    On Order:
    Old Setup:
    Nov 2006
    Bradenton, FL
    32
    1,131
    Anyone?
    *Under Contruction*
    On Order:
    Old Setup:
    MikeNeufeld's Avatar
    MikeNeufeld is offline CarAudio.com Elite
    Feb 2007
    VanCity
    644
    OOOLD thread retard
    Jul 2006
    Georgia
    12,847
    1 Post(s)
    1170 Post(s)
    you can get two .5 ohm amps, or one HUGE 1 ohm amp or two 2 ohm amps. One HUGE amp like a hk4000 or something or 802sx would be efficient. I think your two pa3000s might run at half if you keep them down.
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
    Prowler573's Avatar
    May 2005
    Northwest Louisiana
    45
    18,522
    I'm aware of this - but you were talking about running two subs per one amp hence my remark about a pair (a pair equalling two of something) of DVC 2Ohm subs. As such my previous post stands as stated.
    No - that isn't the only way to wire them by far. However, if you still intend on doing what you stated originally which is run a pair of subs off of one amp - which would equal two amps running 4 subs - then 1/2 Ohm or 2 Ohms is going to be how you'd want to do it.
    oxygen65's Avatar
    oxygen65 is offline Banned
    Jan 2007
    Chicago
    522
    just go with one big amp and run all 4 at 1 ohm otherwise you have to get 2 amps and run them at 2 ohms for each pair of subs
    i think you should just get a ma4000hk or the 802sx and then make sure your electrical can keep up with it
  9. #9
    Nov 2006
    Bradenton, FL
    32
    1,131
    Quote Originally Posted by 99oldsintrigue View Post
    But aren't the HK4000's and 802sx's rated at 17volts? I'm going to be running a 300amp alt and a couple Optima Yellow tops or similar. I plan on keeping my electrical at 14.4, so would those amps still work? I need a amp putting out at least 4K watts, perferablly a little more.
    *Under Contruction*
    On Order:
    Old Setup:
  10. #10
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    30
    3,265
    2 Post(s)
    i'd run two orion 2500d's at a 1/2 ohm on each pair.. i'd bet you'd be happy
    supercoupe enthusiast x9
  11. #11
    01xtreme's Avatar
    01xtreme is offline Senior VIP Member
    Mar 2007
    Bradenton, FL
    175
    Check out the Massive Audio P3000.1 that would work out pretty well if you could run a pair of those since it puts out its power @ 2ohms, or look at the kicker ZX series monoblocks. If memory serves those are 2 ohm amps also. if you want to run 2 amps that is. if not RF T4000 will work if you just want to run 1.
    AVH-P5900DVD
    Sundown 100.4D
    Dayton RS-180's (x4)
    Onkyo 3/4" tweeters (x4)
    18" Fi BTL's (x2)
    RF t4k (sold)
    Everstart Maxx 29 (x4)
    Iraggi 280 amp alt
    Optima Red top
