Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 53 of 53
Reload Thread: how many batts should i get for...
  1. #46
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    Re: how many batts should i get for...
    Quote Originally Posted by pimpedout97x View Post
    i should be able to use the 880 to cross it over right?
    if you say so. sounds to me you have atleast a 4-way system with 10's, 6's, tweets, horns. this is your mess to figure out
  2. #47
    pimpedout97x's Avatar
    pimpedout97x is offline Banned
    Mar 2006
    Tampa, FL
    3,368
    horns + tweets = same crossover point
    6's + 10s = same crossover point
    subs = same crossover point
    _____________________________
    = 3
  3. #48
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    = 3
    Grawwss.
    nG
    http://crunktimes.com/ct/
    nG - BSEE
  4. #49
    darren700's Avatar
    darren700 is offline got bu/\/\p?
    Jun 2006
    Windsor, Ontario, Canada
    485
    3 Post(s)
    = 3
    i think that your going to run into cancelation problems with 6" and 10" drivers playing the same frequencies..
    2009 GMC Sierra SLE Ext Cab
    Hu: Premier P690UB
    Front: CDT ES-6MO, DRT-26a, Upstage Tweeter, 560 Xover
    Amps: Audioque AQ2200 and US Amps MD23
    Sub: SSA Zcon 18 D2 (6.6cu ft @ 28hz)
    Wiring: 2 run Knuconcepts 1/0 ga w/ Big 3
    Elect: Singer 350a Alt.
    Batts: Stock and HC2400
  5. #50
    iceteebone's Avatar
    Aug 2003
    Michigan
    33
    37,876
    = 3
    interesting
    what was the point now of getting 10's?
  6. #51
    neonrt's Avatar
    neonrt is offline What are you looking at?
    Jun 2006
    Canada
    38
    1,687
    1 Post(s)
    For once i am going to post a sensilbe responce in an eminence thread. I know, i know what is the world coming to, but if NG can do it, I guess i could as well.
    I would shy away from the same crossover points for the diff woofers, unless you are cotjones, then go for it, but like its been said you will most likely run into some cancelation. i would skip the 10's, and just run 6's, or vice versa. Heck run more 6's to make up for loosing the 10's. or vice versa. same goes for the horns, and tweets, try crossing them over to play diff freq's. i think i remember you saying that your horns play up to 9k? so cross them over just below that, and cross tweets just above the horn cross, or find a midddle ground.
    Power issue, you said you plan on running a separate power source @16 volt for the hk 4000's, so that is taken care of. for those amps you plan for the "front stage" a 200amp alt should do fine imo as long as you provide sufficient time to recharge batts after a good long time playing them at full tilt.
    kevin
    Quote Originally Posted by Ku-sama View Post
    since I'm under 18, doesn't that mean I can have kiddy ****?? and can't I sleep with a 8 year old?
  7. #52
    Mar 2006
    Tampa, FL
    3,368
    tweets will be in front cabin, horns will be behind the wall, no way there can be cancelation issues.
    and with 12 mids and 8 tweets all in the small area of my 2 front seats, im not really concerned about cancelation lol.
    i may get an external xover tho. ive had like 3 but my friend always takes them lol. i have a brand new legacy one now, donno if ill use it.
    http://www.cardiscountstereos.com/ca...oduct+%23=LXR6
  8. #53
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,726
    20
    65 Post(s)
    YES! LEGACY!!!!
    Lol.
    nG
    nG - BSEE
