RE35-1d vs PPI PCX-2350
alright, i need to make a choice. I am going to buy an amp to run a RE XXX 15" sub that is 1600 watts RMS. These are the two amps that i am going to choose between. I can buy the PPI amp for 500 and the RE amp for 369. What do you all think?
Thanks,
Mark
Here are the specs for the two amps, if you need them:
RE35-1D Amplifier
Highly efficient Class D amplifier topology.
Single channel subwoofer amplifier with 1580 Watts at 14.4 volts
Built in crossover adjustable from 50 Hz to 250 Hz
Remote gain level controller.
Variable subsonic filter from 15 Hz to 40 Hz
Filter matching high pass line level outputs
High torque power(4ga) and speaker(8ga)
Adjustable phase control.
Clipping indicator
Fuse Ratings 3 X 40 amp
3 way protect: clipping, speaker short, and thermal.
Dimensions Heatsink from the top 15.75L X 9.75W X 2H
Max dimensions with terminals 17L X 9.75W X 2H
Amplifier Ratings:
35 watts x 1 at 4 ohms
1100 watts at 2 ohms
1500 watts at 1 ohm
PPI PCX-2350
Channel: 2
4 ohm: 400
2 ohm: 800
Bridged: 1600
Damping: 500
S/N Ratio: 115 dB
Dimension: 2.375" x 10"
Length: 30.25"
THD: 02%
Power Input: 4 Guage
Freq. Resp.: 4.5-100k
I/P Sens.: .15-12V
X/O Slope: 12dB
X/O Freq.: 30Hz-4kHz
X/O Type: 2 way
Input Type: 12 vDC
Cooling Fan: Yes
QBass: QBass™ Plus
I would choose the RE-35 simply because it's cheaper. Both are quality amplifiers and you should not be able to tell a difference between the two as far as sound is concerned.
