Results 1 to 5 of 5
Reload Thread: 2 alpine type-R's 4ohm amp suggestion
    Jared530's Avatar
    Jared530 is offline Drop bombs
    May 2006
    Sacramento, Ca
    2,259
    Hi i just bought 2 12" alpine type-R's and i dont have the slightest clue and what to buy. I was to buy the hyphonics brutus 1500 mono D, but i dont really know anything about amps and subs, so if i bridge this amp, how much wattage do you think ill get at each sub?
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    Re: 2 alpine type-R's 4ohm amp suggestion
    heres the amp specs:
    Mono Brutus Series Power Amplifier
    1 x 450 Watts @ 4 Ohms
    1 x 900 Watts @ 2 Ohms
    1 x 1500 Watts @ 1 Ohms
    Bass Remote with Blue LED Power On & Diagnostics Indicator
    D-Class Design
    Ultra-Fi MOSFETS
    Zeus EVXP (Exponential Vari-Power Supply)
    SPC - Simpatico Coil Design
    HSMD - Hifonics Surface Mount Design
    Fully Adjustable Accu-Cross Crossovers
    PWM MOSFET Power Supply
    Line Output for Amplifier Daisy Chaining
    Variable Bass Equalization
    Variable Sub-Sonic Filter
    4 Gauge Power Connectors
    Additional High Speed MOSFET Output Devices
    Maxi-Fuse
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    33
    37,876
    a mono amp puts out power, and will divide it amongst the subs. so 1500 watts to 2 subs will give you 750 watts a piece. now with that said i'd stay away from hifonics. mixed reviews on wether they do rated power, and how they run at 1 ohm
    Jared530's Avatar
    May 2006
    Sacramento, Ca
    2,259
    can you wire it down to *** little ohms as possible, lets say .5 to get more power?
    prochobo's Avatar
    prochobo is offline Sedan Sleeper
    Mar 2006
    louisville, ky
    1,662
    No, 1 ohm is the lowest you could wire to for those 2.
