Results 1 to 6 of 6
Reload Thread: Can you help me tune my new Alpine MRD-M1005?
    Mynameismcgyver's Avatar
    Mynameismcgyver is offline Buford T. Justice
    Jan 2006
    Long Island, Ny
    1,249
    Hey guys. I was wondering if you could help me tune this amp. I know I got it close but some of these settings i just have No f*ing clue.
    Example:
    What should the crossover freq be?
    30 to 200MHZ
    Low Pass filter switch?
    12 DB or 24DB oct
    Help is certainly apprectiated..
    TSA Team Standard Audio
    2001 Maxima GLE
    Alpine Cda-9827 w/ Xm Interface unit
    Amps- Alpine MRV-F345, US Amps 2000x
    Fronts-PG 6.5 RSD'S
    Rears-6.5 Pioneer Rev's
    Sub-09 Fi BL loaded
    Box-Two six inch aero's
    Batt-Kinetic Hc800
    210A Alternator
    Second skin deadener
    Refs:
    Buyer: lostsuspect21
    Seller: FatboyRacing
    docutech's Avatar
    docutech is offline NC Native
    Dec 2005
    Saint Louis, MO
    1,501
    Re: Can you help me tune my new Alpine MRD-M1005?
    nevermind. sorry
    Prowler573's Avatar
    Prowler573 is offline R.I.P. Gossamer!!
    May 2005
    Northwest Louisiana
    40
    18,541
    Quote Originally Posted by Mynameismcgyver
    Example:
    30 to 200MHZ
    Like I said in your other thread try starting at around 75Hz and then make adjustments up or down from there to see what sounds best to your ears.
    12 DB or 24DB oct
    This is what 'slope' the crossover operates at, or how sharply the frequencies beyond the crossover setting are attenuated out of the output. Remember - a crossover isn't a brick wall that completely eliminates any and all frequencies outside of its setting - but the sharper the slope on the crossover the fewer frequencies outside of the setting will "slip through" so to speak.
    Again - set this according to what sounds best to your ears.
    If i was able to help you at all you're most welcome.
    Refs: [CA.com] [eBay.com]
    Jan 2006
    Long Island, Ny
    1,249
    Excellent. I got my voltage around 42 @ 1.5 on the gain. SQRT(1000*2)=45v
    Although if I drop it down one notch on the gain (like 1.0) it shoots up to 70V. Does that sound right? The sub also doesnt really start bumping till around 20 on the volume although when I listen to my sys loud i have it around 32
    2001 Maxima GLE
    Fronts-PG 6.5 RSD'S
    Sub-09 Fi BL loaded
    Batt-Kinetic Hc800
    210A Alternator
    Refs:
    Blunt's Avatar
    Blunt is offline 2009 ProStock 0-600 Champ
    Aug 2005
    Somewhere
    31
    2,102
    from what i have noticed. if you have the gain set right there will be a point at low volume where you will almost have no sub output.
    Quote Originally Posted by DBfan187
    Ever laughed so hard that your spincter hurt? Think that's what it feels like when you stuck in a cage with an ape during mating season?
    87 S-10 Ext Cab 4x4
    3 Treo SSX 15's
    1 Treo CXT4.1i
    2 200 amp Ohio Gen Alts
    2009 USACi Pro Stock 0-600 World Champion
    TEAM DB DRIVEN
    TEAM TREO
    BROKEN SILENCE C.C.
    refs: HCCAfan,meka,slain93gsr,spitfirees20,iceteebone,sa kura,john payton,Mr. Loki, 96MaxGLE, speedfreak28
    Jan 2006
    Long Island, Ny
    1,249
    oooo ok. So I guess im alright.
    2001 Maxima GLE
    Fronts-PG 6.5 RSD'S
    Sub-09 Fi BL loaded
    Batt-Kinetic Hc800
    210A Alternator
    Refs:
  1. alpine mrd m500 what subs should i run?
    By 67impala in forum General Discussion
    Last Post: 08-01-2005, 09:03 PM
  2. alpine iva d310
    By limitkid7 in forum Head Units
    Last Post: 04-28-2005, 05:51 PM
  3. Infinity Reference 1230W 12" + Alpine MRD M300 = ?
    By sandwiches in forum Amplifiers
    Last Post: 05-13-2004, 02:02 AM
  4. alpine 9807 vs alpine 9811
    By borisshnitkin in forum General Discussion
    Last Post: 03-18-2003, 07:17 PM
  5. Alpine mrd m500 vs. Jl audio 500/1
    By boominbass in forum Amplifiers
    Last Post: 01-16-2003, 01:10 AM
