Results 1 to 3 of 3
Reload Thread: HELP! broken amp? or fuse problems? HELP!
    lesesneje's Avatar
    lesesneje is offline Member
    Oct 2005
    north carolina
    27
    37
    i have a sony XM-D400P5 800 watt amplifier. every time i hook it up and turn the car on. the two fuses on the amp blow but the car fuse is fine. The fuses on the amp are 2x30amps and the main battery fuse is a 50amp. does anyone know why this is happening? could it be something wrong with the amplifiers inside parts?
    imaspaceguy90's Avatar
    imaspaceguy90 is offline LOUDS10BLAZER=SCAMMER
    Jan 2005
    Melbourne,FL
    23
    2,507
    17
    Re: HELP! broken amp? or fuse problems? HELP!
    SOmetimes that can mean a blown amp, or some of your wires on the amp may be crossed. Make sure none of your speaker cables or rca cables are damaged
    REFS:
    1.Erik019*2.BoominBeast*3.SBLAZER
    4.Jordantyler*5.80INCHES*6.Unbonyr
    7.zachzchw*8.Codyst8n*9.10.11.Raven2201X3
    12.Terryracing86*13.Lastcall*14.Milenko515
    15.Dont_smokerocks*16.LoudS10Blazer
    17.Jimmclrk1*18.Mattbrown0761
    19.20.ProjectPat06X3*21.Mountaineer Man
    22.Fosgate140*23.I want SExxx*24.zeanimal2001
    25.Seiser01*26.Dj-torn*27.JeremyZach*28Netherland24
    29.Mjbailey21*30.Skeptikal*31.Ravens9322
    32.Calico33*33.mattmcss*34 ibanezcollector 35.terryracing86
    36 Jordantyler 37 PWRBASS 38.keifersracing
    39. BATman 40 keifersracing 41PhatTonyDeMarco
    LoudS10Blazer IS A SCAMMER
    lesesneje's Avatar
    Oct 2005
    north carolina
    27
    37
    How can i tell if the amp is blown? What should i look for? i looked inside the amp and none of the transitors seem to have become unsaudered. everything on the inside LOOKS to be okay and the wires are brand new. just took them off of my kenwood that was running my hcca and it was pounding prety hard. is there a specific part of the inside of the amp i should check out?
  1. Alpine CDA-9813 power fuse rating
    By Cosmic Charlie in forum Head Units
    Last Post: 09-12-2005, 06:44 AM
  2. fuse by battery necessary??
    By noob with an RS in forum Wiring, Electrical and Installation Help
    Last Post: 03-22-2005, 08:26 AM
  3. Inline fuse...how close to battery?
    By deaf16 in forum General Discussion
    Last Post: 03-11-2005, 05:31 PM
  4. Fuse holder near battery
    By tractng in forum Wiring, Electrical and Installation Help
    Last Post: 12-04-2004, 03:05 AM
  5. Amp power from battery
    By jheaton57 in forum Wiring, Electrical and Installation Help
    Last Post: 09-30-2004, 10:26 PM
