Results 1 to 2 of 2
Reload Thread: 3 10 inch re xxx amp help
    h18's Avatar
    h18
    h18 is offline Junior Member
    Jun 2004
    san diego, ca
    if i get 3 10 inch RE xxx dual 2 ohm what amp should i get and what would it be at 2 ohm or what i dont know, i need help?
    BassAddictJ's Avatar
    BassAddictJ is offline CarAudio.com Veteran
    Apr 2005
    FL
    12,837
    1 Post(s)
    128 Post(s)
    Re: 3 10 inch re xxx amp help
    wire the subs in series to 4 ohms each, wires those in paralelle you'll have 1 .33333ohms....
    all depends on ur budget, id recommend a memphis mojo 2000D or an orion 2500D
    FORMER SETUP:
    Pioneer Avic N5 Navi + CD-UB100 USB Adapter. RARE Circa 1996 PPI Ax606.2 in BLACK (1 of 400ish made) with 2 rare black graphic spacers.
    CDT DRT-25 1'' Silk Dome Tweeters / CDT ES-04 4'' Midranges / RE Audio XXX 6.5'' 2ohm Neo Mids In Glassed Kick Pods
    American Power Systems 240amp H.O. Alty / (2) Deka 8a31, 1/0 front to back.
    Unknown Prototype 3k @ 1ohm. TRF/PSI 8 layer 4in coil hybrid beast in 3 cubs @ 33Hz / Raammat 40sqft in the trunk.
    Quote Originally Posted by Haunz View Post
    You could put 12V to my balls and clamp my dick to get 3kW+.
    Quote Originally Posted by Slayerx View Post
    Glad this got bumped so I could fap to it again.
  1. Amp for 2 10 inch L7's
    By JasonsFB34 in forum Amplifiers
    Last Post: 03-16-2004, 09:08 PM
  2. need an amp for 15" XXX
    By ThumpInDaTrunk in forum Amplifiers
    Last Post: 03-09-2004, 01:47 AM
  3. Which Amp is good for VEGA 10''?
    By <IowaBoomer> in forum General Discussion
    Last Post: 12-16-2001, 08:16 PM
