MMats m2000.1
up for sale is a mmats m2000.1d works great has some blemishes as pictured,i ve only sold one item on this web sight and still new to selling up here,but i have sold right much on ebay,and i have this on ebay right now jbw0077 259 posifeedback,id rather sell it up here cause ebay gets 9% of final sale,there is absolutely nothing wrong with this amp,other than the cosmetics,and its not that bad,im just peculiar.too be as small as this amp is it is a true power house!i will ship same day as payment sent,if possible,you will not be dissatisfied,paypal is perfered payment that way we are both protected,here are some specs:2000rms@1ohm and 1100@2ohms
M2000.05D/M2000.1D/M2000.2D
M2000.1D
STABLE TO: 1ohm
CONTINUOUS (RMS) POWER
@ 13.8 Volts 2000rms@ 1ohm and 1100@2ohms
Signal to Noise Ratio A-Wtd: <85dB <85dB <85dB
Total Harmonic Distortion: 0.3% 0.3% 0.3%
Channel Separation: N/A N/A N/A
Input Sensitivity: 150mV-2.5V 150mV-2.5V 150mV-2.5V
Slew Rate: 13V / Usec 13V / Usec 13V / Usec
Fuse Rating: 100 amp 100 amp 100 amp
Dimensions:
Height: 2.25” 2.25” 2.25”
Width: 9.5” 9.5” 9.5”
Length: 10” 10” 10”
General Information:
Frequency Response: <10Hz to 275Hz
Low-pass Filter: Variable 24db, 77 to 275Hz
Battery Connectors: 2 Gauge
Speaker Connectors: 8 Gauge
CONTROLS AND CONNECTORS
(1) Positive Power Terminals –This is the power feed from the positive (+) terminal of the car’s battery. Use 4-gauge cable (MINIMUM) and good quality terminals when routing this connection. Tighten all connections well to prevent power loss due to bad contact. Route the power cable away from the RCA jacks and speaker cables
(1) Ground Terminals - For optimum performance, use 4-gauge cable MINIMUM! Connect this cable to your battery’s negative (-) terminal or to a secure area of the body in the trunk. *See note below.
Remote Terminal - The amplifier will turn on when 12 volts is applied to this terminal. This 12-volt signal is usually taken from the Power Antenna or Remote wire coming from the source unit.
Speaker Terminals - Connect to speakers using 16-gauge wire (minimum). Running too low of a speaker impedance will cause the amplifier to go into a fault condition.
Crossover Filter – Linkwitz/Riley 24db slope. This control sets the 6db down point of your amplifier.
Gain – Allows input levels between 150mV (max gain) and 2.5 volts (min gain) for full output.
Recommended Fuse – 80 amperes.
Recommended Battery: You should use 1 battery for each pair of amplifiers. If your system uses only 1 amplifier, then the starter battery is sufficient. Note: When you have to parallel 2 or more batteries together always use the same, size, brand and amperage of battery. This will ensure that the batteries charge equally. We do not recommend battery isolators. At 2 or more batteries, you will need to upgrade your alternator. The starter battery should always be upgraded with a high output audio battery.
Note: If you use the chassis as a source for your ground in the trunk, you MUST increase the size of the wire that runs from the front battery to the fender. Remember; 12 volts has to run in a continuous loop and if you do not increase the ground wire up front the voltage/current will be restricted and your system will not play to its fullest.
free
[I]http://i1048.photobucket.com/albums/...ps8da01fb5.jpghttp://i1048.photobucket.com/albums/...ps917f7258.jpghttp://i1048.photobucket.com/albums/...pse17301bd.jpg
