+ Reply to Thread
Results 1 to 15 of 15
Reload Thread: Can you get "competition grade" SQ on home drivers?
    LoudSound's Avatar
    LoudSound is offline Senior VIP Member
    Dec 2016
    Toronto
    174
    86 Post(s)
    Can you get that "artist in front of you" sound using home drivers? faital pro 3fe22 mids in the pillars along with some kind of silk tweeter to be exact. Or do you need expensive sq components?
    The difference I noticed between "good" systems and "amazing sq systems" is that in SQ systems every instrument stands out so much from the others, as does the voice. And the sound is so warm. How the hell do these guys do it? Some kind of dark magic I swear.
    Boomin_tahoe's Avatar
    Jul 2005
    WA
    14,257
    41 Post(s)
    6035 Post(s)
    Re: Can you get "competition grade" SQ on home drivers?
    Why would you use home drivers inside your car? Your more than likely better off using raw drivers, such as from http:///www.partsexpress.com then run them active off a good HU, such as Pioneer 80 prs or something similar. To get that in your face artist feeling depends upon driver placement and time alignment. All this takes time to do. It's not an overnight thing to happen. @Jeffdachef can give ya more input than this as he's the expert in the field.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,964
    240 Post(s)
    7783 Post(s)
    its the same sh*t lmao.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    Jeffdachef's Avatar
    Feb 2013
    15,964
    240 Post(s)
    7783 Post(s)
    Quote Originally Posted by LoudSound View Post
    Network mode tuning, quality drivers, perfect time alignment and proper EQ tuning. sound treatments, turning your door into a perfect speaker enclosure aka Keep Hope Alive's build logs. Just some deadener alone wont work, thats basically near garbage still.
    Jul 2005
    WA
    14,257
    41 Post(s)
    6035 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    Well perhaps I'm picturing OP removing his tower speaker drivers and somehow massage them in his car....depending upon what drivers they are, better off starting from scratch with raw speak-ah's.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Jeffdachef's Avatar
    Feb 2013
    15,964
    240 Post(s)
    7783 Post(s)
    most pre-made home setups use the drivers from parts express. Its literally no difference.
    Jul 2005
    WA
    14,257
    41 Post(s)
    6035 Post(s)
    Gotcha.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    LoudSound's Avatar
    Dec 2016
    Toronto
    174
    86 Post(s)
    The only thing going in the door is an 8" midbass, and would play just that. The inside of a door treated with dynamat makes for a great enclosure. The midrange would ideally go in the pillar along with the tweeter.
  9. #9
    Jeffdachef's Avatar
    Feb 2013
    15,964
    240 Post(s)
    7783 Post(s)
    well i'm just judging from your current setup and how it might be able to be improved. A pillar mids are the way to go to bring the stage up.
  10. #10
    LoudSound's Avatar
    Dec 2016
    Toronto
    174
    86 Post(s)
    it appears the main difference between home and car drivers is that car speakers are designed for better off-axis performance. whereas the home drivers play the sound in front of them(lows are better at going off-axis, so a dedicated midbass in the door will work fine)
    So yea I Don't see why it can't work.
  11. #11
    LoudSound's Avatar
    Dec 2016
    Toronto
    174
    86 Post(s)
    im doing this guys. gonna win all the competitions
    competitions for being the biggest tool on the block
  12. #12
    hispls's Avatar
    hispls is offline CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    10,102
    15
    38 Post(s)
    4138 Post(s)
    The sorcery of which you speak is time and money mostly.
    It can work. As you say, "car" drivers are typically made for better performance off-axis. Really a car is just an awful acoustic environment so that's your #1 hurdle to get over. You can pick any driver you like of reasonable quality and with enough digital processing and trial and error as far as location and aiming make it sound very good. Pillar mounted tweeters and 3" full range/midrange is a tried and true method. You'll need some time alignment for sure to center the stage and may still have some peaks and nulls. Give yourself a way to put any high mounted pods on a swivel so you can tweak the aiming of them. A small adjustment in the aiming of a tweeter on one side can make a dramatic difference so allow yourself some flexibility and with sufficient patience in testing you will get there.
  13. Thanks LoudSound thanked for this post
  14. #13
    Jcsaudio's Avatar
    Jcsaudio is offline Senior VIP Member
    Sep 2017
    Worcester, MA
    274
    3 Post(s)
    122 Post(s)
    I have been using and testing various raw drivers from Parts Express and Madisound in all my vehicle and all active setups with great success. I find You get better quality drivers for less money provided you do your research and pick the right drivers. The Celestion 3 full range drivers Im currently using in my CX5 are hands down the best Ive used yet.
    2014 Sienna 2-way active SQ system. SB Acoustics SB29RDCN Tweeters. Focal PS165V mid woofers. Pioneer D9500F 75 watts RMS x 4. Pioneer BHS 5800 HU. AudioControl EQX. 10 Alpine SWS sub in custom ported box tuned to 35 hz on JBL GTX 500.
    2014 F-150 XL WT 2-way active budget SQ system. Tang Band 25-302SH 1" tweeters. Dayton Audio ND140-4 mid woofers. Alpine 40 WPC x 4. Alpine MRP 450 at 400 watts RMS x1. JL Audio Twk 88 DSP & FIX 86. Sundown SD3 10 sub sealed .5 cubes.
    2014 CX5 3-way active SQ system. Pioneer 1330 NIX HU. Dayton AMT tweeters. Celestion AN2775 2-3/4 midrange. NVX XSP65 mid woofers. Pioneer PRS D4200F 75 WPC x 4. Infinity K1000. JL Audio Twk 88 DSP. Sundown SA 12 sealed.
  15. #14
    LosIsATool's Avatar
    LosIsATool is online now CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,950
    109 Post(s)
    7671 Post(s)
    Quote Originally Posted by Jcsaudio View Post
    Heres the issue. Home drivers are more quality for less. But if you understand the parameters you will see they are designed to be installed in sealed cabinets. Car drivers are designed for IB. Also moisture protection and UV.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
  16. #15
    Jcsaudio's Avatar
    Sep 2017
    Worcester, MA
    274
    3 Post(s)
    122 Post(s)
    Quote Originally Posted by LosIsATool View Post
    This is true, especially for larger midbass and woofer drivers; so you do have to select carefully there. For tweeters though, you can score big time over more expensive lesser quality automotive specific types, provided you can fit them as some are large. For mid range drivers where an enclosure is less important, especially the higher you high pass them, you can attain great results.
    For the OP, Car Audio | DiyMobileAudio.com | Car Stereo Forum is a place where this has been discussed many times and where members share their experiences. If you want to learn more than that is the place to go. As LosIsATool stated, you do have to be careful about moisture control within a door with a woofer for example. In my CX5, the back of the woofer is protected and out of the drip line of the window above. I did however take some precautions and created some rain shields just in case. The Dayton woofers in my truck use neodymium magnets with underhung VC that is shielded from the enviromeant and they have been in their for a year now without issue.
    Im just getting into small full range drivers and so far im impressed. I think my goals are different than most here so it all depends on what youre looking for. Every vehicle and every person will be different.
+ Reply to Thread
  1. Where if anywhere in Michigan can you get MECP Certified?
    By jalverson in forum General Discussion
    Last Post: 02-06-2006, 01:02 PM
  2. Where can you get a sub rebuilt?
    By lostsoul in forum General Discussion
    Last Post: 04-28-2005, 02:21 AM
  3. how thin can you get?
    By paikiah in forum Subwoofers
    Last Post: 01-29-2003, 09:37 PM
  4. Audiobahn 1200q where can you get them for a $100
    By xxsaintdawgxx in forum Subwoofers
    Last Post: 09-28-2002, 02:15 PM
