+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: Preferred frequency response curve?
  1. #16
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    14,785
    199 Post(s)
    7057 Post(s)
    Re: Preferred frequency response curve?
    Quote Originally Posted by Papermaker85 View Post
    i set my sub high as i can without drawing the stage rearward its really a level matching issues when you have your phase/time alignment right..
    you have the PWXs sealed? how do they do with the substage when its cranked?
    man @ciaonzo sold me the best sounding PA drivers I've ever heard these things legit play do to 35hz up well into the midrange with ease and sound transparent. alittle dryer than my 6.5s but still very realistic maybe more so than my 6.5s around 250 to 500.. they are super clean even moving more than im comfortable with a midbass moving. lol i wouldn't be suprised if they have 7 ot 8mm xmax
    my sub stage is right there by the B pillar so its kind hard having it being dragged behind me since it already feels like its in front even at full tilt.
    By itself it feels like I already have subs in my car with the subs turned and hpf still at 80hz. With hpf off or at 50hz its literally sub bass central and my door panels cant handle it even with all the deadening I did, lowest it played with authority was 28hz. It keeps up midbass wise until about 152 db then the sub stage completely drowns it whenever a 40-55hz note hits, its fine with 35hz and under material.
    I normally dont bass loud anyways since I live in the city and I dont like shaking people's houses I only bass hard if i'm on the freeway or doing demos at shows. So i'm at most listening to at most 140db of sub stage max on the daily.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  2. Likes gotgixers liked this post
  3. #17
    Papermaker85's Avatar
    Papermaker85 is online now Better built than bought!
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    **** wish you where closer.
    for years i told peeps walls sounded better. not so many phase issues(trucks sometime with 2 woofers but 4 woofers port in the center works great) you can hear the woofers and the woofers sound much more upfront. cars downright **** for systems.
    Insidious Audio
  4. #18
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    ditto on cranking it. when you do 150+ on music its actually pretty disturbing and disrespectful. unless your dowtown by the clubs ten you ARE the club. lol
    Insidious Audio
  5. #19
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    twenty past four
    4,496
    2 Post(s)
    1707 Post(s)
    look here.. when got into actual sound i realized i've been listing to bass mekanik all wrong all these years. you don't know ho much the 80-250hz range make the bass complete! get you a good pair of 10" PA drivers with 400 per side. you will thank me later
    Maybe one day but for now it's all about spl.
  6. #20
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    Quote Originally Posted by THATpurpleKUSH View Post
    im about to do a SPL install. lol im gonna try to do a easy inchangable port and tuned low for daily but its gonna be a burp build..
    Insidious Audio
  7. #21
    Sep 2009
    twenty past four
    4,496
    2 Post(s)
    1707 Post(s)
    The one I'm beginning to work on will be strictly for burps and the entire thing (amp, box, h/u, electrical system) will be completely removable after the show and is powered 100% by batteries.
  8. #22
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    what batteries? id suggest a nice cap bank to avoid voltage sag!
    Insidious Audio
  9. #23
    ciaonzo's Avatar
    ciaonzo is online now TheContinental
    Feb 2009
    WI
    42
    10,682
    15 Post(s)
    1015 Post(s)
    Yeah, those things are monsters. High sensitivity, stupid power handling, and gobs of clean excursion for crazy output with headroom to spare. B&C makes those for McCauley for use in one of their high fidelity concert line array systems. Unicorns for sure, glad you're enjoying them.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  10. #24
    Sep 2009
    twenty past four
    4,496
    2 Post(s)
    1707 Post(s)
    XS D1400 so the voltage stays up. I figured 50ah should get me a total of 26-30mins of burping. It sucks that a charger for a 14v agm is $200.
  11. #25
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    Quote Originally Posted by ciaonzo View Post
    i want another pair! im glad i got um. the freak drum tracks are so loud that it exceeds some band drum lines i've heard and i only havve 250 per side i want to do 400. thanks again! lol
    Insidious Audio
  12. #26
    ckirocz28's Avatar
    ckirocz28 is offline Junior Member
    Aug 2017
    Birmingham,AL
    4 Post(s)
    What curve do you guys prefer?
    I like the smiley face curve for the most part
    Bass slowly sloping down to about 500 with the largest dip around 4k and a shallow rise from 12k up.
    I like a relatively flat curve until 50hz and below.
    I also like girls with small tops and nice bottom ends.
    Sent from my SM-G935U using Tapatalk
    Pioneer DEH-80PRS
    Memphis Audio MCX-4.75 and PRX-1500.1 amplifiers
    JL Audio C3-650 convertibles in dash
    Pioneer 4-way 6x9s in rear
    RE Audio HC15
    1988 IROC (5-speed, 5.7 liter)
  13. #27
    Dec 2006
    New orleans LA
    32
    11,798
    63 Post(s)
    2 Thread(s)
    4834 Post(s)
    Quote Originally Posted by ckirocz28 View Post
    lol. i can't stand the honky sharp mid to upper mid-range to be so forward but i love that air and sparkle 14k+ gives.. i like big ******* and big booties. most of all i like squirters
    Insidious Audio
  14. #28
    Sep 2009
    twenty past four
    4,496
    2 Post(s)
    1707 Post(s)
    Squirters
  15. #29
    Jeffdachef's Avatar
    Feb 2013
    14,785
    199 Post(s)
    7057 Post(s)
    eh, this is the best I can do with my sh*tty phone mic. Still got 6 volume clicks to go but anymore than 56, that tiny smart phone mic eats sh*t completely. This is at 80hz high passed.
+ Reply to Thread
  1. Replies: 3
    Last Post: 02-17-2016, 01:19 AM
  2. Replies: 0
    Last Post: 01-10-2004, 05:23 AM
  3. 15 HC Frequency Response, good or bad?
    By TJD15HC in forum Subwoofers
    Last Post: 05-23-2003, 04:07 PM
  4. frequency response
    By drew in forum Amplifiers
    Last Post: 06-16-2002, 02:47 PM
  5. Frequency response
    By Killa sin in forum Subwoofers
    Last Post: 02-19-2002, 07:52 PM
