+ Reply to Thread
Results 1 to 12 of 12
Reload Thread: T/a question
    loudenuff's Avatar
    loudenuff is offline CarAudio.com Elite
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    T/a question
    I'm running 2 way active on my 80prs and I'm curious, when off axis (90 degree left side, about 45-60 degree right side) do I set ta distance based on how far the speaker literally is from me, or how far the speaker would be from dead center in front of me?
    John Kuthe...
    LosIsATool's Avatar
    LosIsATool is offline CarAudio.com Veteran
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Re: T/a question
    How far it's from you. Axis doesn't matter if it's not beaming. At the point a small format tweeter will beam it's getting into the higher range that's hard to hear anyway.
    Once you put in the numbers use mono pink noise to dial in the center.
    Also delay on tweeters isn't as important as intensity.
    2014 Ford Fusion SE 2.0T
    JBL MS-8
    DD M1c, DD SS4A
    IDQ12v4 1.8cu sealed
    Hertz HT28
    Hertz HV165XL
    Knuconceptz OFC, Custom fit Soundrive RCAs.
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Re: T/a question
    Quote Originally Posted by LosIsATool View Post
    What do you mean by intensity? Eq?
    John Kuthe...
    ilikeradios's Avatar
    ilikeradios is offline Senior VIP Member
    Sep 2011
    Pigeon Forge, TN
    359
    1 Post(s)
    209 Post(s)
    Re: T/a question
    Quote Originally Posted by loudenuff View Post
    Volume ie. level
    My stage gets higher the more I raise the level of my dash mounted tweeters.
    trumpet's Avatar
    trumpet is offline CarAudio.com Veteran
    Jan 2011
    Grafton, ND
    36
    6,792
    43 Post(s)
    1859 Post(s)
    Re: T/a question
    Get within an inch of the center of the cone or dome and you'll be fine. The left and right EQ strategy is much more important.
    Rubyserv - I believe I can delivery joy every time you drive by the power of an incredible sound system. Barry Schanz, Owner
    Authorized dealer for CDT Audio - Shop With Us Now.
    FB | Rubyservsales
    IG | Rubyserv
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Re: T/a question
    Quote Originally Posted by ilikeradios View Post
    Volume ie. level
    It may get higher but it won't be stable.
    I'll try to find the stage test track. If you do to far the female in the middle will move to the side once she gets higher pitch.
    Intensity as in volume, output.
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
    The Camry's Avatar
    The Camry is offline Hey, I Try.
    Sep 2013
    Western Oregon
    2,776
    13 Post(s)
    1254 Post(s)
    Re: T/a question
    Actually i believe that pioneer head units do it differently than you would if you had an external dsp. Pioneer figures out all the math after you just plug in the Real world measurements. Just use a tape measure for base line and then change your settings till you get center stage.
    Gain on an amplifier to meant to be matched to the output voltage of your headunit. Think 3 volt, 4 volt, 5 volt pre out specs you see on headunit specs. This is how gain works for a given pre out(5 volt) theoretically. However most head units clip(start to distort) at around 80% of your volume so your 5 volt pre out wont give 5 volts Cleanly. You will most likely get 4 volts out at something like 33/40 on your volume knob and would thus set your gain to 4 volts. (these things can be measured with a GOOD Multimeter. )
    80% of your total volume is (max volume) X 0.8.
    Example is 40(is your max volume so, 40 X .8=32
    Jeffdachef's Avatar
    Jeffdachef is online now Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    15,086
    217 Post(s)
    7244 Post(s)
    Re: T/a question
    Set crossovers first and formost.
    Measure distance from each driver and plug it to the unit in inches, then use a proper centered track and make adjustments till both tweet and mid are independently centered aka turn off the mid, do the tweet, turn off the tweet do the mid. Then EQ.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  9. #9
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Re: T/a question
    Thank you for all of the answers. So when it comes to eq, how do I know which ones to tinker with? This will definitely be a challenge once I get the c-dsp hooked up. I'm not sure which hz need adjusting. There's 3.5k 4K 5k 8k 12.5k and 20k if I remember correctly, and when I adjust I can't really hear a difference until I go -6 (all the way down). I have the mic that came with the unit, but I have heard numerous times that it is a shizzy mic and not even worth using
    John Kuthe...
  10. #10
    LosIsATool's Avatar
    Apr 2011
    Pensacola, Florida
    37
    17,645
    106 Post(s)
    7465 Post(s)
    Re: T/a question
    RTA and download REW. Dayton has a pretty cheap mic on parts express.
    Putting on your big boy pants now
    JBL MS-8
    DD M1c, DD SS4A
    Hertz HT28
    Hertz HV165XL
  11. #11
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Re: T/a question
    Wanna link that mic for me? I've seen a few and I'm not sure which one will have the accuracy I'll need. Will be downloading that program tonight, I'll play around with it so I can figure out how to use it. I'm also picking out tweeters and mids soon, but I'm stuck on something. I'm pretty sure it was you who referred me to the tang band titanium and bamboo 3" correct? My only issue is one, they're rated at like 15wrms, and two they're 8 ohm. My cv v600/4 doesn't have an 8 ohm rating but since most tweeters are 8 ohm, would I be alright going 8 ohm, or would I have to do a set of mids and tweets per side to do 4 ohm?
    Also, I've noticed that a majority of midbass drivers I've looked at are 8 ohm. I wouldn't mind running two per door but their rims rating is too high for me to do 2 per channel, and I also don't understand how I'd set them up to run 2 active speakers on one channel. I believe I've read about a possible way to do this, something about being within a quarter wavelength of each other, but I don't really understand what that means and every topic I lookup regarding, doesn't seem to give me a direct answer for what I need
    John Kuthe...
  12. #12
    loudenuff's Avatar
    Jan 2015
    WA gwon?
    712
    10 Post(s)
    295 Post(s)
    Re: T/a question
    My amp for the midbass is a jx360/2
    John Kuthe...
+ Reply to Thread
