Results 1 to 13 of 13
Reload Thread: need help trying to align 3 way active
    zen's Avatar
    zen
    zen is offline Member
    Aug 2011
    Ca
    84
    9 Post(s)
    hi boys
    i have a problem like tittle says
    everything on a jetta mk3
    set up
    hu eclipse cd7000
    cdt cl-6 tweeters right up to mids on door 2¨-3¨ inch far from mids
    cdt cl-6 mids OEM place
    cdt m6+ lows mounted on rear deck
    today during morning finished to setup my first 3 way active
    everything sound amazing like i was thinking.
    but i noticed 1 or 2.. of them is not a aligned well
    actually i know tweeters are. but very difficult to me how to
    any help how could i align them well
    i did it all by ear (change my ears not an option :P )
    thanks
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    Mids amp pg tantrum 500.2
    twts amp sony xm6020
    with no subs
    pickup1's Avatar
    pickup1 is offline CarAudio.com Veteran
    Aug 2005
    Roanoke,TX
    53
    8,454
    19
    7 Post(s)
    832 Post(s)
    Re: need help trying to align 3 way active
    Without any kind of dsp, amp gains and crossover points.
    Are you using the head unit for processing?... doesn't it do 3 way,but lows are the sub?
    rizmanzali's Avatar
    rizmanzali is offline Junior Member
    Apr 2014
    malaysia
    1 Post(s)
    make sure the polarity first and you may also can play the phase.... i mean, run in phase or out of phase...
    zen's Avatar
    zen
    Aug 2011
    Ca
    84
    9 Post(s)
    thanks for reply...
    yes im doing it with hu
    lows crossover point 125hz 24db/oct
    mids high pass 125hz 18db/oct
    mids low pass 4khz 24db/oct
    highs high pass 4khz 24db/oct
    yes pickup without dsp
    i was using same song all time
    about subs, cdt´s m6+ in around sealed .38 cu/ft each tuned around 60-50
    i tried disconecting lows´ rca just mids and high and than just tweeters...and than tweeters off and only mids and finally when i thoght i did it. when hear it everything togheter, sound like something is wrong. sound pretty good, but some part of mids on voices sounds here and highs sound there
    gains on amp are allmost in minimun (or 2-5 volts, don´t remember it is 4150 crlx arc audio)
    and cdt´s m6+ kicking with mrp m350, dont remember where this gain is. but also should be near to minimum
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    with no subs
    zen's Avatar
    zen
    Aug 2011
    Ca
    84
    9 Post(s)
    Quote Originally Posted by rizmanzali View Post
    what i remember about speakers all are in phase ( + with + and - with -)
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    with no subs
    zen's Avatar
    zen
    Aug 2011
    Ca
    84
    9 Post(s)
    thanks for replied
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    with no subs
    rizmanzali's Avatar
    Apr 2014
    malaysia
    1 Post(s)
    yes..but you may also try to reverse the polarity speaker. there are different sound 0-180° in your cabin. and sometimes you may listen the center stage.. a good one you may get sound 2 or 3 meters in front of you..
    rizmanzali's Avatar
    Apr 2014
    malaysia
    1 Post(s)
    by the way.. dsp is still important.. it will help how to blend all sound come out from each speaker..
  9. #9
    zen's Avatar
    zen
    Aug 2011
    Ca
    84
    9 Post(s)
    i haven´t tried changing polarity because of my rca´s are broken since like a week a go and need to buy 2 2 channel or one 4 channel rca
    i was thinking that if you have a good hu (thinking also that cd7000 eclipse, is a good one, with good stuff eq, T/A, 3 way active, x over) was not so important to have dsp.
    but im guessing now, that still important to have dsp (**** expensive hobby :P ) i though when i buy cd7000 ¨yeah! dont need to buy an external, dsp to be able to make 2 way o 3 active. no need a x-over and of course not a eq...
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    with no subs
  10. #10
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,078
    28
    47 Post(s)
    1500 Post(s)
    you have a decent setup that is capable of good things.
    phase matters a lot. polarity is absolute but phase is relative to position and crossover slope. keep in mind that crossovers adjust phase.
    6 db/oct is a 90 deg. shift
    12 db/oct is a 180 deg. shift
    18 db/oct is a 270 deg. shift
    24 db/oct is a 0 deg. shift
    30 db/oct is a 90 deg. shift
    use all 24 db/oct and you eliminate phase shifts.
    start by setting T/A based on distance from each ear to each voice coil. your main issue will be the midbass behind you.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
  11. #11
    calebkhill's Avatar
    calebkhill is offline CarAudio.com Elite
    Dec 2012
    Phenix City, Alabama
    1,103
    326 Post(s)
    Do you have time alignment?
    Can you control the level of your drivers independent of each other?
    Good time alignment, L/R eq, and making sure your speakers are in phase will help improve the system
    "When I listen to a stereo loudspeaker playback in my room and an auditory scene has formed in my mind, how would I know that what I hear is an accurate replica of an auditory scene that could be had at the recording venue? Or more generally, that this is an auditory scene that could have existed at all?"
  12. #12
    rizmanzali's Avatar
    Apr 2014
    malaysia
    1 Post(s)
    agree with keep_hope_alive.
    doesnt matter if you want to use dsp processor built in HU or the other one.. external dsp with amp.. but it really help on this. time alignment is most important thing for the sq setup and the tonal you can made adjustment by active/passive crossover and eq setting.. good luck
    Kenwood epsilon dynaquest
    rainbow sac 265.25 kick
    dls ultimate ur reference series
    JL vrc sealed box
    belden.Rockford
  13. #13
    zen's Avatar
    zen
    Aug 2011
    Ca
    84
    9 Post(s)
    never could try changing phases on speakers for this, change rca´s but than y sell my amp and dont want to take back ads, got to move everything again... but i have other question that will be right topic, about small box for 12 sub, but big port (it seems to me, 36sq inches) but its too long
    Hu pioneer 80prs
    2 way active
    mids Dynaudio 5.25
    twts Dynaudio 1¨
    with no subs
  1. I really need help trying to figure out a box for a Fi btl 18"
    By rookanga in forum Enclosure Design & Construction Help
    Last Post: 07-06-2010, 08:36 AM
  2. Replies: 13
    Last Post: 06-11-2010, 04:30 PM
  3. need help trying to get my new sony MEXBT2600 to work...
    By canadeanbkn in forum Wiring, Electrical and Installation Help
    Last Post: 05-10-2009, 06:00 AM
  4. need help! trying to match subs to kickerzr600 amp
    By skinz187 in forum Subwoofers
    Last Post: 02-01-2007, 11:35 AM
  5. Need help trying to find a kenwood?
    By DRAGonShadow in forum General Discussion
    Last Post: 07-06-2002, 12:38 AM
