+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 46
Reload Thread: What are some SPl tricks or tips you have learned?
  1. #16
    05fronty's Avatar
    05fronty is online now SALT PETER
    Nov 2006
    conway,ar
    39
    10,950
    49 Post(s)
    Re: What are some SPl tricks or tips you have learned?
    put a fat guy in the passenger seat with you
    bought from ridinhi,vitveet,dbr,sicaudio and 99grandprixgt, and more ........... sold to player3,foomasta69, pitbull, brodiesel and dragnix 12887 traded with louisiana crx
    "noobs that come in the dome will get gang raped!"
    nothing but a stock fosgate system with gps and back up camera lol
    2012 nissan sentra spec v with some goodies cumming though
  2. Likes Heel4lyfe liked this post
  3. #17
    r0llinlacs's Avatar
    r0llinlacs is offline Member
    Oct 2011
    Iowa
    89
    1 Post(s)
    Quote Originally Posted by pro-rabbit View Post
    You should try sub up or forward and port to the passenger side. Might be surprised at the outcome.
    Doing that eliminates trunk gain, and in SUV's eliminates cabin gain. In all my experiments in trunks, facing rear with sub AND port will net up to 5db versus front or up firing, depending on the car. Front or up firing is a little cleaner and more even sounding, but not as loud or punchy in my experience.
    Deck Kenwood KDC-X595 (For now)
    Mid/High Speakers Infinity 6x8 Coaxial's and RF P1 Tweeters in front doors
    Mid/High Amp Orion 280GX 2x80wrms (Old school)
    Sub Rockford Fosgate T1D412 12" 800wrms
    Sub Box 2.5 Cubic foot, high output, slot ported
    Sub Amp JL Audio 1000/1 v1, 1000wrms @ 11-14.5 volts
  4. #18
    r0llinlacs's Avatar
    Oct 2011
    Iowa
    89
    1 Post(s)
    Quote Originally Posted by 05fronty View Post
    LOL, passengers actually absorb the sound waves and make it less loud.
  5. #19
    NASTY08IMPALA's Avatar
    NASTY08IMPALA is online now CarAudio.com Veteran
    Aug 2012
    LOUISVILLE, KENTUCKY
    2,916
    31 Post(s)
    Quote Originally Posted by r0llinlacs View Post
    Trunks with subs forward and port to drivers side is pretty dam loud ..as good or better than subs and port back ..thats how.my new box wil be setup @dbeez ;just did a box for 2 12" zv3.s on a saz4500 pretty nasty
  6. #20
    dbeez's Avatar
    dbeez is online now CarAudio.com Veteran
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Yeah I will disagree with some of that statement.
    2002 suburban
    Security System Code alarm
    Electrical Dc power sp270 7 deka 9A31's and lots of 1/0
    Headunit pioneer 880prs
    Amps Sax125.2 front stage 2 dd M4a's strapped@ 1 ohm
    Wiring lots of 1/0 stinger, tsunami
    Mids & Tweeters Dd w6.5 mids and lanzar opti crossovers and tweets
    Subs 4-18" nightshade v2's d2
    System DetailsDaily driver.
  7. #21
    Falcons's Avatar
    Falcons is online now that **** i dont like
    Jan 2011
    Albion, New York, United States
    5,099
    17 Post(s)
    Quote Originally Posted by dbeez View Post
    What statement? And what parts?
    Things to look forward to:
    (2) 10" or 12" imperium audio designs subs
    set of PHD MF 6.5" comps
    Completely seal off and deaden my doors
    aquire a 2k amp
    aquire a 2 channel amp for front stage
  8. #22
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    Quote Originally Posted by Falcons View Post
    Give me a bit to get to a comp my phone doesn't like this sub forum.
    2002 suburban
  9. #23
    dbeez's Avatar
    Nov 2008
    crestwood,ky
    8,760
    51 Post(s)
    ok i will disagree with the 5 db gain and the cleaner sounding that is a peronal prefrence type of thing what one person finds soothing another will hate so thats your opinion. subs forward and port side have yielded great results when done right box specs tuining and whatnot but test test test and you will find what is best in your application as every vehicle is different even when they are the same car sometimes the results will vary.
    2002 suburban
  10. #24
    pro-rabbit's Avatar
    pro-rabbit is online now Moderator pro-rabbit is a Supporting Member of the forum!
    pro-rabbit is a Supporting Vendor of the forum!
    Jan 2004
    OKC, OK
    31
    12,057
    348 Post(s)
    What all have you actually tested to give you this number? Most trunks that I (and many others) have built to get loud did not fire back at all.
    Also, to suggest anything would give someone a 5db increase is....well...just not accurate.
  11. Likes n8skow liked this post
  12. #25
    r0llinlacs's Avatar
    Oct 2011
    Iowa
    89
    1 Post(s)
    I had an 87 cadillac that sounded horrid with front firing subs. Ported or sealed, it didn't matter. Rear firing did net me 5 more db. But it's different in every car. My car now only benefits 1-2db from rear firing.
  13. #26
    pro-rabbit's Avatar
    Jan 2004
    OKC, OK
    31
    12,057
    348 Post(s)
    If they are sounding "terrible", that has more to do with enclosure design and various settings then anything. Most of the time it is not as simple as just moving the enclosure around because it does load differently.
  14. #27
    Aug 2012
    2,916
    31 Post(s)
    Ur talking subs and port forward and yes i agree sound bad unless u seal off from cabin...were talkin port firing off drivers quarter panel
  15. #28
    mlstrass's Avatar
    mlstrass is offline Shaggy DOA
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    Maybe on your planet but on Earth I've seen numerous vehicles gain .1 - .3 on the meter with a passenger and NONE have ever lost
  16. Thanks 05fronty thanked for this post
  17. #29
    mlstrass's Avatar
    Jul 2006
    Illinois
    9,576
    12 Post(s)
    I will be sure to tell all the loud guys at finals that they're doing it wrong...
  18. Likes DLP_Customs liked this post
  19. #30
    05fronty's Avatar
    Nov 2006
    conway,ar
    39
    10,950
    49 Post(s)
    actually i gained .2 putting someone up there when i metered in my frontier. not lying either. i have people who can vouch
+ Reply to Thread
  1. What are some good 4" or 5-1/4" speakers??
    By Krazykilroy in forum Speakers
    Last Post: 04-15-2012, 01:02 PM
  2. What are some of the Weakest subs you ever used?
    By ThomasG in forum Subwoofers
    Last Post: 03-03-2007, 09:33 AM
  3. Replies: 2
    Last Post: 06-18-2004, 01:36 AM
