Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Reload Thread: 147 db on a LOW tuned box
  1. #16
    Joe562MMA's Avatar
    Joe562MMA is offline CarAudio.com Elite
    Apr 2012
    Los Angeles , CA
    29
    696
    209 Post(s)
    Re: 147 db on a LOW tuned box
    cool ima get a bigger amp send some more power to um
    either skar or sundown 4500.
    Mixing my martial Arts
  2. #17
    sacsking916's Avatar
    sacsking916 is offline stayin high an loud
    Apr 2009
    emerald triangle..home of da trees
    6,428
    323 Post(s)
    So the box is turned low but doesn't necessarily that score is from that low.
    TEAM AUDIO TECHNIX
    TEAM SSC
    TEAM CADENCE
    Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
    Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
    Quote Originally Posted by CRXBMPN View Post
    King James has nothing on King Sac!
  3. #18
    subzero's Avatar
    subzero is offline CarAudio.com Veteran
    Sep 2008
    Phoenix, AZ
    41
    6,785
    30
    7 Post(s)
    454 Post(s)
    150 @ 28
    2016 Chevy Cruze LT
    Pioneer DD 2700BS , JBL MS8 all active , ARC XDI805 channel, FOCAL-100KRS set - active- Dayton Audio SD215A-88 8" DVC Subwoofer as Midbass - sub- one Crescendo Forte 12., (1) Alpine-MRD-M1000
  4. #19
    Buck's Avatar
    Buck is offline always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Quote Originally Posted by TaylorFade View Post
    Not bad? Lol. How many people on here can do [email protected]?
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
  5. #20
    wenn_du_weinst's Avatar
    wenn_du_weinst is offline CarAudio.com Veteran
    May 2007
    4,633
    1275 Post(s)
    how many people can do it from 25-80hz? then I'll be impressed.
    I am protesting Skar by giving them added exposure in my signature.
  6. #21
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    I can do it from about 27 to 55. Who wants to do a 147 over 60 hz though? Do you want your subs to play that high?
  7. #22
    May 2007
    4,633
    1275 Post(s)
    my subs don't play over 45hz right now, and will probably be dropped down to 40hz after I get better mids. Doesn't mean there should be a drop in volume. The biggest problem with this whole argument is the fact decibels do not say how loud something is, I want no audible dip in output, I could care less what score it does.
  8. #23
    Buck's Avatar
    May 2008
    Nashville
    18,643
    28 Post(s)
    1117 Post(s)
    Quote Originally Posted by wenn_du_weinst View Post
    But if your subs don't play over 45 hz, how is that not a drop in volume to 80?
    And if you have a drop in volume over 60, you can have an increase in volume in other places
  9. #24
    May 2007
    4,633
    1275 Post(s)
    because like I said, db's do not dictate audible output. If you were to sit in a car doing 150db at 2khz you would go deaf instantly, it's much much louder then 150db at 35hz. you can be down 10-20db and have the same volume just depends on the freq
    ---------- Post added at 01:30 PM ---------- Previous post was at 01:29 PM ----------
    and my system doesn't dip because I built it not to.
  1. So High & Low tuned box's Question
    By SLIM3001 in forum Enclosure Design & Construction Help
    Last Post: 04-03-2007, 06:55 PM
  2. limited space for a low tuned box, little help
    By colgatekillaa in forum Enclosure Design & Construction Help
    Last Post: 10-03-2006, 02:48 PM
  3. Tuning on a home audio box??????????
    By poopspoon in forum Enclosure Design & Construction Help
    Last Post: 06-17-2006, 11:59 PM
  4. Pros & Cons for a low tuned(~28hz) box
    By CJL in forum General Discussion
    Last Post: 04-08-2006, 11:42 AM
  5. Replies: 5
    Last Post: 04-07-2003, 10:34 PM
