+ Reply to Thread
Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 112
Reload Thread: Tweeter Spheres - pics and examples
  1. #91
    Iosias's Avatar
    Iosias is offline Senior VIP Member
    May 2012
    United States
    408
    5 Post(s)
    Re: Tweeter Spheres - pics and examples
    If it doesn't look or work that well im gonna try and find a source of cheap ball stock and have our machinist just mill some out lol.
    Refs # Tallc, CleaRSkieS, Roth, Goindef154, Kangaroux, tv559
  2. #92
    Iosias's Avatar
    May 2012
    United States
    408
    5 Post(s)
    This is the basic design, I can adjust it for any size tweeter and have it printed out or possible milled out in a cnc depending on cost.
    Any recommended change or something I should consider ?
  3. #93
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    5,030
    28
    124 Post(s)
    Depends on the tweeter. If it has a lip, you want a matching lip. Each tweeter mounts differently. Looks good. It would be nice to see a bit more surface area around the tweeter. I have some paper mâché eggs that I will experiment with also.
    have you been helped by me? i'd love to know. shoot me a PM.
    My 2001 Accord build log:
    http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    Can I help you? valencebandacoustics@gmail.com
    Want to learn about car audio electronics?
    http://www.bcae1.com
  4. #94
    Kingstroker's Avatar
    Kingstroker is offline Mr Dique
    Oct 2012
    Guthrie, OK
    329
    1 Post(s)
    in general terms, is aiming toward the head rest on each side better imaging than aiming across the dash?
  5. #95
    May 2007
    Quad Cities, IL
    5,030
    28
    124 Post(s)
    aiming at the rear C-pillar (opposite side) for each tends to work out well - result is a wider sound stage than aiming at head rests.
    you'll need to attenuate the nearest tweeter if they are more on-axis.
  6. #96
    husker77's Avatar
    husker77 is offline CarAudio.com Elite
    Apr 2012
    Nebraska
    651
    5 Post(s)
    Quote Originally Posted by keep_hope_alive View Post
    Ok I've done some google and searching, but what is the difference btw on-axis and off-axis? And what do you mean attenuate?
  7. #97
    May 2007
    Quad Cities, IL
    5,030
    28
    124 Post(s)
    imagine a laser beam coming out of the center of a tweeter (or speaker). that is the axis. you are on the axis (tweeter pointed at you) it is on-axis. if you are not (tweeter pointed away from you) you are said to be off-axis. being off-axis should be further clarified with an angle (in degrees) with 90 degrees being perpendicular. this factors into the polar response of the speaker/tweeter at each frequency. polar plots are useful in determining what you will hear as you move from being in front of a speaker/tweeter to what you hear when it is pointed away from you.
    attenuate is just a fancy word for "turn it down". decrease level/volume of the nearest tweeter and the sound stage will become more centered (since we localize sounds above 3kHz based on intensity (volume) and not on pathlength).
    thanks for asking for clarification. i'm sure it will help other as well.
  8. Thanks husker77, gckless thanked for this post
  9. #98
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    I'm not sure if I am gunna aim mine at the seats they closest to or the opposite
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  10. #99
    May 2007
    Quad Cities, IL
    5,030
    28
    124 Post(s)
    The :intent is for each person to have the left tweeter in the left year and the right tweeter in the right ear.
  11. Thanks husker77 thanked for this post
  12. #100
    cablguy184's Avatar
    cablguy184 is offline SQ "White Lightning"
    Oct 2010
    Rankin Co. Mississippi
    42
    448
    1 Post(s)
    Gee Wilikers !!!!!
    I just spent about an hour going through this thread ... Excellent !!!
    There is plenty of very cool ideas on here for tweeter installations !!!
    Thank you
    Randal Johnson ... Comcast Xfinity ... 1997 Chevy Silverado 1500 Extended Cab
    Linear Power / Blues Car Audio ... Audio Technix ... Hyper Automotive LEDs and HIDs
  13. #101
    TheUnderFighter's Avatar
    TheUnderFighter is offline Beer Addict
    Mar 2011
    Murrieta, California, (SoCal)
    22
    3,406
    28 Post(s)
    Here's some well overdue pics of the spheres KHA made for. Fortunately, I had the same tweeters as him, so measurements were easy! I just had to give him angles.
    2009 Hyundai Elantra - Budget Sound in Progress
    HU- Kenwood eXcelon KDC-X994
    Fronts- Crescendo MP6 mids, Vifa Ring Radiator tweets on Arc KS300.4
    Subs- Single SA-10 on Mmats 2000.1 @ 1ohm
    Misc- 1/0 CCA from AT, Big 3 in Stinger HPM, and AT 60 mil deadener
    Bought from: Inferno333, select127, treesive, Kangaroux, DonH
    Sold to: coolest user, Psychodrama, MidgetClown, mr.tigger, av83
  14. #102
    Mar 2011
    22
    3,406
    28 Post(s)
    I used Rustoleum textured spray paint, and it matched my panels very well.
  15. #103
    cablguy184's Avatar
    Oct 2010
    42
    448
    1 Post(s)
    Very Nice
  16. #104
    husker77's Avatar
    Apr 2012
    Nebraska
    651
    5 Post(s)
    @keep_hope_alive ; is the goal to have the paths cross at a certain point in the vehicle? Part of the reason I ask is that 2 of the vehicles I am thinking of doing this on are pickups, so no c pillar to aim at. I know I can just guesstimate, and am probably over thinking it.
  17. #105
    cablguy184's Avatar
    Oct 2010
    42
    448
    1 Post(s)
    I'm thinking that what makes these things so interesting is that you can adjust them at practically any given time without modification ...
    This would make perfect sence when tuning for Sound Quality. Wether it be one seat judging or 2 seat judging ... east adjustments ...
    I would suggest to start out by aiming them to your interior cab light ... and adjust from there
  18. Thanks keep_hope_alive thanked for this post
+ Reply to Thread
  1. blow thur pics and a few other system pics
    By xchaosx in forum Enclosure Design & Construction Help
    Last Post: 08-16-2004, 06:37 PM
  2. **Magnum d2 ****** pics and vids!!!
    By ngsm13 in forum Subwoofers
    Last Post: 07-12-2004, 02:26 AM
  3. New Install Pics and Info (Denon, AC, PG, JL)
    By josh99ta in forum General Discussion
    Last Post: 07-01-2004, 02:16 AM
  4. Pics, pics, and more pics!!!!!!!
    By SpeedJunky in forum General Discussion
    Last Post: 04-19-2004, 01:57 AM
