+ Reply to Thread
Page 9 of 15
FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 121 to 135 of 215
Thread: >>>Engine whine and ground loop fixes... take two
  1. #121
    dman4486's Avatar
    dman4486 is offline Paid to Post
    Jan 2008
    Central, SC
    9,357
    Feedback Score: 0 reviews
    Re: >>>Engine whine and ground loop fixes... take two
    Quote Originally Posted by southbark33 View Post
    I have opened up my DEH-P5900iB headunit, but am unable to locate even a single fuse... I cannot find any tags labeled with FU-???
    I am lost, I would be able to fix this headunit if only I knew where the dang fuse was... any help on this model would be appreciated
    take some pics and then we can help
    Auto: 96 honda passport 3.2L v6 4X4 5sp
    Big 3 pics--THE MAV--THE RSD's--MY VLX
    Rices Creek Pics
    Refs: Sold to; lilmaniac2, alexdbest2000, jshak07 Bought from; CJL
  2. #122
    southbark33 is offline Junior Member
    Apr 2008
    Westford, MA
    Ok, i bought the service manual for $10 online, I found the fuse, it's on the underside of the circuit board... go figure. Wasn't incredibly hard to disassemble the entire thing, just tedious.
    Well, I soldered on a 1-ohm 1/4 watt resistor in place of the pico-fuse, hooked the HU back up in my car and still recieved the god awful engine whine...
    I'm almost positive I took off the correct fuse... it had a little "p" on it and was labeled FU-352.
    Is it because I used a wrong type of resistor? it seems like it should be fine...
    I'm opening it back up right now, I'll take some pictures and upload them.
  3. #123
    Apr 2008
    Westford, MA
    pics of the back side of the motherboard, with a 1ohm 1/4 watt resistor soldered onto where the fuse used to be.
    Still receiving awful noise.
    I have the RCA cables grounded right now instead, because the RCA grounding works well as a temp fix. It reduces the noise by about 90%, but I'm really just not satisfied... I want that fuse fixed for good, but the resistor isn't doing a ****ed thing. Any help/comments would be helpful
    Thanks guys
    Pics:
    http://i35.photobucket.com/albums/d1...3/IMG_1988.jpg
    http://i35.photobucket.com/albums/d1...3/IMG_1989.jpg
    http://i35.photobucket.com/albums/d1...3/IMG_1994.jpg
    I also have the service manual if anyone wants a look at it for the DEH-P5900iB model
    If it'll help you diagnose my problem then I'm more than happy to share it, hit me with a pm
  4. #124
    canadapettit's Avatar
    canadapettit is offline Long Rod von HugenSchlong
    Oct 2006
    albany, Ga
    25
    395
    Well i could tell you a way that you could check to see if the fuse is any good,but now that you replaced the pioneer fuse with resistor it won't work. My guess is that the fuse is still good since you were getting signal to the amp. If that fuse was blown, you would get no sound. My only suggestion is to check all of your grounds and make sure that they are good.
    EDIT: make sure you did change the correct fuse. It should have been no bigger then a grain of rice and been very hard to see with out a magnifying glass.
  5. #125
    Apr 2008
    Westford, MA
    Quote Originally Posted by canadapettit View Post
    are you referring to the Pioneer HU's?
    The Pioneer HU's have an external fuse, it's easily visible, birght red 10amp fuse that prevents too much power from passing thru the headunit, a safety feature. However, the fuse that I and most other people are talking about is the pico-fuse inside of the HU on the backside of the circuitboard. This fuse is what grounds the RCA preouts internally. If that internal pico fuse blows, you recieve overpowering engine whine, which is what I'm getting right now. I was searching through another forum with the same topic and they said that they fixed it removing the blown pico fuse and replacing it with a 1ohm 1/4 watt resistor, which is what most HU's have instead of a fuse.
    I tried that method and it didn't work for me. I tested the connection between the pico fuse prior to taking it off and it wasn't giving me a reading.
    Yes I def changed the correct one, I was referencing the schematics and the fuse was about the size of an eyelash with a little letter "p" on it, with the tag "FU-352" next to it.
  6. #126
    Cellmice is offline Junior Member
    May 2008
    Philly Pa
    Wow great sticky. After reading all the pages i fix my stupid wineing noise also. Been messing around with the system 3 days and after reading this and doing the ground the rca's it finally fix it.
    Thank you very much everyone for the tips.
  7. #127
    WOT's Avatar
    WOT
    WOT is offline Banned
    Nov 2007
    Toronto,CANADA
    3,715
    So how do you guys ground the rcas when the outputs arent right on the back of the headunit? :Like my RCA outputs off my pioneer have 8" cables so the connections isnt right on the back of the deck, how would you ground them still?
  8. #128
    95Prober's Avatar
    95Prober is offline CarAudio.com Elite
    Nov 2004
    Canada
    1,112
    so when i accelerate on the road, my engine whine increases, its especially bad while listening to the radio. for the most part, my music drowns out the whine when playing a cd
    is this a typical alternator problem or Pioneer head unit, since thats what im running?
    thx
    MY SET-UP :
    Head Unit :Pioneer Premier P660 w/ card remote
    Subwoofers :4-12" Pioneer Premier TSW-1241 (Dual-Voice Coils)
    Sub Amps :2 Zenon ASB-2200.1
    Speaker Amp:Soundstream Rubicon 604 (4Ch.)
    Rear Speak Fill:6x9 Infinity's
    Front Speak:CDT (CL-641 3-Way Comps in custom kickpods)
    Wires/Cables/Installation :2 runs of 0/1 guage, Knukonceptz RCA's, battery terminals, fuseholders, and 12,14 guage speaker wire and.. The Big 3
    Sound deadening : 30sq.ft of Secondskin & 150 B-Quiet Extreme for doors etc., 200 sq.ft of Edead v.2 for floors and trunk
    Box:6 Cu.Ft @32Hz
    Refs:scottyk,Fuknmovin,Bavarian3,Blados,Blazrgreg,juckstapose,
    acousticguitar,IonSQL,SQBubble,dragnix,02parkave,
    DUMPED
  9. #129
    Blazin_Jason's Avatar
    Blazin_Jason is offline CarAudio.com Elite
    Oct 2005
    Vancouver Isl, BC, Canada
    26
    1,159
    Just installed a p600ub yesterday and at low volumes it was making noise. I ran a ground directly from the battery to the head unit and it made no difference at all. Wrapped some 20g wire around the rear outputs and noise completely gone.
  10. #130
    robinson,jerry is offline Senior VIP Member
    Feb 2008
    chicago
    33
    289
    this whine problem just happend to me. i have a clarion h/u grounding rcas only makes it louder my system has been the same for almost 2 years,it just started after i started my car one morning
  11. #131
    ultimate157's Avatar
    ultimate157 is offline Engineering Student
    Mar 2006
    Worcester, ma
    7,127
    Quote Originally Posted by Blazin_Jason View Post
    Thats because the grounding issue is a loop contained within the head unit itself.
    '98 Jeep Grand Cherokee
    Source: Pioneer 880 PRS *Active
    Tweeters: 1" CDT TW-25
    Midrange: 6.5" CDT CL-65
    Sub: 15" SSA Icon
    Box: 4.0 @ 32hz
    Amp: Soundstream Tarantula 2kW
    Feedback thread
  12. #132
    MSUBlake827 is offline Junior Member
    Aug 2008
    Lake Charles, LA
    Anyone ever have a problem using two ground loop isolators on same vehicle? I installed one between my iPhone and my AUX in on the back of my headunit and then another one between my SUB OUT and my Input on my amp. When both are hooked up I get the same engine whine with really bad feedback through my subs that wasn't there before the isolators. But with just the one for my AUX in hooked up, there is no more engine whine. What is causing this?
  13. #133
    Oct 2005
    26
    1,159
    Quote Originally Posted by ultimate157 View Post
    Well my noise was gone for a while, but it has returned. I will have to see if the grounding I added came loose maybe. Might look into a 9886 instead.
  14. #134
    na_rsx's Avatar
    na_rsx is offline Incriminator Audio FTW
    Apr 2007
    With Jessica Biel
    3,731
    okay, picked up a 780mp, i love the 880prs, but i love the look of the 880prs. well the 780mp had the horrible alt whine, so decided to do the rca ground trick.
    had some remote wire, so i cut 6 pieces, put one in each rca, then tied all them together. then grabbed some kicker 16 gauge, found a screw on the headunit chassis. took of the screw, put the wire, tied everything together, wrapped it in electrical tape. and presto, shit is gone, its still there, but only 1%.
    2005 Acura RSX-S
    Headunit: JVC KD-AR8500
    Front Stage: Vifa & Mpyre 65M *ACTIVE*
    System Amp: MB Quart DSC4125
    Wiring: Kicker Hyperflex
    Deadening: Edead SE2 and V3
    Refs:
    Bought from: mlstrass, archie, brchd, BigOso, bk12321, Ricky 616, IonSQL, SilverSPL, VIPER118, fived, jdiddy, Tacosys, ls2poweredgoat, SethPhillips, DB_DRAG_SPL, bjfish11, XaznKewLguy, Integra2468, Incriminator, bur1196, Goindef154, amartin_72
    Sold to: vitveet, aesoj, DejaWiz, jco1385, Lax916, iowaaurora, Zeuslicious, chrispizzitola, gkatmar, Racerx250, boltpride, zeed, Low_e_Red, xreymax, hrtbrk1, RKPsk8er, Anniku989, bradknob, andrios
  15. #135
    big dawg is offline Junior Member
    Jul 2008
    cincinnati
    18
    I have an eclipse cd7000 and i have horrible engine noise. I put ground isolators on my preouts for my front and rear rca cables and they didnt help. I tried grounding them to my head unit and it didnt help. can anyone tell me where i can ground my headunit? In my 2001 bonneville, there is no metal behind the radio. Also, should i try to ground my rca cables at the amp as well? Could a bad amp ground cause this problem so badly?
+ Reply to Thread
Page 9 of 15
Latest Posts Loading...
Loading...
Loading...
Loading...
Loading...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
