RF2000db VS Fusion 2500d
  • Rockford Fosgate 2000db
    Votes: 9 75.0%
  • Fusion 2500d
    Votes: 3 25.0%
  • Total voters
This thread is dumb, I bet no one who votes has used both let alone either of these amps. I have owned a T20001bd and I have seen clamp tests on fusion amps. The NV2500 will do more then the RF and it will go to lower ohm loads. Good luck getting the RF to run at .5 lol.
i have both these amps and im guessing off top of the head.....the fusion does 2500w rms @ 0.5ohms....but i've head people gettin up to 3000w rms from the rockford w/great electrical.
for the difference they would be pretty identical enough for daily even if there was a 500 watt diff between the 2...I know the fusions are a pretty solid but extremely fugly amp. You can also get them cheaper I would think!
Stick with the Rockford. It's a quality amp. Fusion are not junk, I just feel they are not up to Rockford quality.
quality or name? Yes Rockford is made in the USA but thoze fusion amps are well built as well! heres my input since you said you already had them why dont you run both amps and c what you like //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif Rockfords always have that WOW factor on people thou just cuz the name.
I was thinking the cost verses the price of a new subwoofer wouldnt be worth the effort. Fusion Audio wasnt a very well made brand of audio in general
909
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Well I finally had a chance to hook up the us acoustics amp. What a difference. Still playing around with the 13 band equilizer. The h/u put out...
Donks
Donks
CO, Ohio
DonH
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
