+ Reply to Thread
Page 5 of 6
FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 81
Thread: Effects of Compression
  1. #61
    Beat_Dominator's Avatar
    Beat_Dominator is offline Yea, thats Mecha Godzilla
    Mar 2005
    Phoenix Arizona
    27
    21,955
    Feedback Score: 0 reviews
    Re: Effects of Compression
    You better Jmac
    And to recent questions, I'd say XM is pretty close to 160kbps MP3. A little bit chopped off at the high end and kind of flat through the midrange.
    Comming Spring 2009
    I make rear-loaded, double crabshell, isobaric enclosures.
  2. #62
    PRIVATEpastry's Avatar
    PRIVATEpastry is offline CarAudio.com Veteran
    Jul 2005
    Omaha, NE
    2,153
    We already went over that.
    Quote Originally Posted by PRIVATEpastry View Post
    I'll quote NetPedia (http://www.netipedia.com/index.php/XM_Satellite_Radio):
    Audio channels on XM are digitally compressed using the aacPlus codec from Coding Technologies for most channels, and the AMBE codec from Digital Voice Systems for some voice channels. Due to bandwidth restrictions and a large channel load, the maximum bitrate XM broadcast from its satellite per music channel is limited to 64kbps.
    And the talk channels are obviously going to be lower quality, I'm guessing 32kbps.
  3. #63
    pinkfloydms is offline Senior VIP Member
    May 2007
    mid south
    166
    WHat about HD radio?
    Also are mp4 or ACC higher quality than mp3?
    www.shroomery.org
    99' 4 Door Chevy Blazer
    HU - Kenwood Excelon kdc-x990
    Front - Polk MMC6500
    Amp - Alpine pdx-2.150
    Sub - FI.Q 12 Sealed
    Amp - Alpine pdx-1.1000
  4. #64
    ShakesAllDay's Avatar
    ShakesAllDay is offline Senior VIP Member
    Aug 2007
    Southern Illinois
    219
    Most of the time, I can tell when I'm listening to a 160kbps or less mp3/wma. Lower bitrates have a weird *tingy* sound to them... very easy to hear the compression.
    192kbps is much better and I believe it to be the best middle of the road bitrate (wrt SQ vs. file size).
    Personally, I find gigabytes too cheap to encode at anything less than 320kbps. The only problem w/ that is you can't fit as many files on a CD.
    I have yet to try any lossless format.
  5. #65
    tcguy85's Avatar
    tcguy85 is offline CarAudio.com Veteran
    Feb 2007
    Hyde Park, NY
    25
    3,527
    and this is why i only listen to rap and hip hop in mp3 format. rap and hip hop sounds like shit anyway so it doesn't matter. :-)
    07 Scion tC: 880PRS, ID OEM 6.5" mids, Seas neo alum tweets, DD S4 and DD C2a amps, Dayton Ref H.O. 10(.7net, tuned to 30hz)
    HT: Samsung PN58B560 - 80gig PS3 - Yamaha RX-V2500 - Infinity Alpha 50 mains - Alpha center - Harmon Kardon HKB6 rears, Epik Sentinel & ED eQ.2.
  6. #66
    jblayz1's Avatar
    jblayz1 is offline CarAudio.com Elite
    Aug 2007
    Miami, FL.
    686
    .flac and .shn are two more lossless formats but few mobile audio HU's play them.
    References: 3.5Max6spd, db Dom, theitalianjob76, redcalimp5, karkrazee96, altima98, eric12421, Blazin Bass
  7. #67
    jamesmington's Avatar
    jamesmington is offline Senior VIP Member
    Aug 2007
    houston
    160
    I've run into a problem recently, in which I think my compression rates may be the source. I just installed an Eclipse CD7000 thats hooked up with a pair of CDT components, and I play my ipod through the headunit's auxillary input.
    Many of the songs that I play have an "airy" sound, in which it is dominant more in some songs than others. Is this due to compression rates, faulty wiring, wrong headunit settings or what?
  8. #68
    oneiztoomany is offline Member
    Aug 2007
    USA
    116
    where can you find high bitrate songs for IPOD?
    Itunes now is offering some of their music at 192kbps which still isn't all that impressive...
    2004 acura tsx // CDA-9887, SPX-177r, type s coax for rear, PDX 4.100, PDX 4.1000, Single 12 in. Type X - sealed box //
  9. #69
    tcguy85's Avatar
    Feb 2007
    Hyde Park, NY
    25
    3,527
    what happened to this thread???
  10. #70
    Aug 2007
    USA
    116
    it was compressed to oblivion
  11. #71
    apw122 is offline Member
    Apr 2005
    Reading, Pa
    118
    I like how there is a 5 page thread where each post is a month after the previous, except for now of course
  12. #72
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,394
    Quote Originally Posted by oneiztoomany View Post
    Most private torrent trackers such as What.cd, Waffles.fm and STMusic.org require bitrates above 192k CBR, with many things available in 320 CBR or V0/V2 variable bitrate.
  13. #73
    Aug 2007
    USA
    116
    where can i get these private torrent trackers?
  14. #74
    bigbang's Avatar
    bigbang is offline Senior VIP Member
    May 2007
    IL
    193
    Hey, I store all my music in AIFF lossless on my iPod. My question is when I add one of my friends burned CDs to my iTunes library, I don't have a clue what the quality of that burned CD is so I import it with AIFF. Any idea how to know what the bitrate/format is on the burned CD and how to import the format directly without up converting it to AIFF so that I can have a clear picture of the quality of my files without everything in my iTunes library saying "AIFF file" even though some may have been ripped from a low quality audio CD? My friends CD's aren’t MP3, they are audio CD's so does this mean there is no way of determining the true quality of the recording because it has been unconverted by default to play as an audio CD?
    I hope for an answer in the next year or so.
    97' Toyota Camry, lol
    Pioneer Premier DEH-P980-BT & iPod interface
    160 Gig Ipod
    Optima Yellow Top
    Stinger 0 gauge wire, distribution, PDH5 cap, RCA's
    MTX 1501D monoblock
    2 Audiopulse 12" EPIC Subs - Sealed Box, 1.5 cubes per sub
    MTX 1004 four channel
    Infinity Kappa Perfect 6.1 components, front & back
    Dyanamat throughout
  15. #75
    joker0907 is offline Joker
    Aug 2008
    indiana
    197
    ok so for someone who downloads everything from limewire and puts them on itunes... how bad is it to do that and once they are downloaded is there a way to make them any better when you put them on a cd or ipod ? or are u just stuck with the compressed version.
    car: 2001 buick century
    subs: 2 12" kicker L5s dual 2 ohm
    amp: fusion nv-am25001
    head unit: dxz585usb
    box: made by pinoeer~saturn
    front stage: 5.25 KAR coaxils and tweeter set
    rear stage: stock
    amp for highs: still undecided
    bought from : Pioneer~Saturn, Team H&K
+ Reply to Thread
Page 5 of 6
Latest Posts Loading...
Loading...
Loading...
Loading...
Loading...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
