+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 15 of 18
Thread: 16 volt systems
    IH8RICE is offline Member
    Jun 2004
    minnesota
    136
    Feedback Score: 0 reviews
    16 volt systems
    any one know how to get 16 volts going to my amp from the 12 volts system in the car, i can only get around 14 to the amp and even with the 5 farad cap i have i have problems with the volts fluxuating. i need to know how to keep a steady 16 volts to my amp, at least 16!!! help my before the compitition season!
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    you have to buy a 16V/12V turbo start battery and a 14Vstepdown or a 16V alt
    Scarenius's Avatar
    Scarenius is offline Call me Ravo
    Jul 2004
    Michigan
    479
    Re: 16 volt systems
    New alt + voltage regulator + big 3 + bigger wires. You'll never get a stable 16 volts, but hey, that's about as good as you'll do.
    Current Setup
    "Power is probably the least efficient way of increasing SPL."
    - Jmac
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    actually, you dont need bigger wires.
    more voltage= less current draw from the amp
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    what do i need to buy to get a sonsitant voltage of "around' 16 volts to 20 volts max to my amp?? low voltage is killing me in compitions i hve 2 extra batteries and a 5 farad cap and still the volts drop bad.
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    a 16V battery
    a 14V step down ( to car)
    a 16v step up ( to battery from alt)
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    where do i get hte step downs and step ups and how much ?
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    check PM
  9. #9
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    i found the step down resistor for the 16 to 14 on turbostart.com but how do i charge the 16 volt battery on the 2 volt system
  10. #10
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    you get the step up, its very expensive.
    The 16/12V battery and a 16V alt would be cheaper
  11. #11
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    would a 16 volt alt wreck my electrical system or would every thing jsut run at 16 volts?
  12. #12
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    nope, thats what the 16/12V battery is for
    16V to the amp, 12V to the rest of the car
  13. #13
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    so if i take out the 2 12 volt batteries and swap it with the 16 volt on from turbo start and get a step up resistor i should be set? then i wouldnt have the change teh 180 amp alt i have ?
  14. #14
    supa_c's Avatar
    Apr 2004
    In a chair
    19,919
    Re: 16 volt systems
    nope.
    swap out the 12V batteries and the 12V alt.
    Put the 16V alt and the 16/12V battery in.
    Thats all you have to do
  15. #15
    Jun 2004
    minnesota
    136
    Re: 16 volt systems
    then the car system would be 12 volt and the audio system would be 16 right?
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Latest Posts Loading...
Loading...
Loading...
Loading...
Loading...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
