+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
Thread: How do you mount large door pods without visible screws?
    boostNbeer is offline Banned
    Nov 2009
    CA
    396
    Trying to think of a way to mount door pods, that goes the entire length of my door panel, and like 12" high with a good bit of weight to it to my door panel without any visibl screws showing
    I can screw it right to the door where the speaker cutouts are, but the end 2/3 of the pod will just be carpeted wood panel.
    How would you attach that?
    etznova's Avatar
    etznova is offline CarAudio.com Elite
    Sep 2005
    Cherry Valley, il.
    29
    1,902
    Re: How do you mount large door pods without visible screws?
    from the back side of the door panel
    99 Ext. Cab Sonoma
    Sub: 2- DD 9515 in 10cubes no wall
    Sub Amp:Stetsom 4K2D
    Midbass: AA carbon fiber mid
    midrange: 4" Tang Band
    Tweet: Seas
    Powered by: Memphis 3004
    here to buy's Avatar
    here to buy is offline Crescendo
    Dec 2008
    Florida
    1,284
    Take the door panel off,
    mount/place a 3/4 birch or mdf piece behind some part of the back where you feel will hold up that side well.
    Now put the pod in front of the door panel where you want it to fit exactly.
    Take 2 inch or 1 5/8" deck screws and screw them through the wood support anchor peice into the door panel, and into the base of the pod.
    Do that on both the speaker side and the closed side and you'll have secured and stable pods
    Nov 2009
    CA
    396
    Quote Originally Posted by here to buy View Post
    I dont want screw heads showing, Im trying to find a discreet way to mount it
    tylork92's Avatar
    tylork92 is offline CarAudio.com Elite
    Nov 2008
    North Carolina
    1,954
    if your gonna make the mold outta fiberglass glass bolts in them
    93 Ford Ranger
    PG RSD 6.5s up front in custom panels
    1 15" DC LVL4
    Sundown SAZ 1000d
    Hifonics Txi 6406 (eventually go with a Sundown sax-50.4 when i find one cheap)
    pioneer 6x8s in rear
    Big 3 in 1/0
    Feedback: http://www.caraudio.com/forum/showth...67#post6284367
    RJesus is offline CarAudio.com Elite
    Sep 2009
    Philly
    1,302
    If you glass bolts in them, there would be no way to get inside to secure it, unless you take off the outside door mold....
    My stock door has a screw that is covered by a cap. Its like a washer with a plastic cover attached to it that blends in with the panel pretty well.
    If I were you, I would mount a block of wood sticking out perpendicular to the door.
    Mount the screw from the bottom/sides of the panel, so they won't be visible. Then cover them with caps of some sort.
    sold to: fatboyracing, Plottin4success, MrSplorDie
    bought from:RumbleNTheTrunk, lmllopez, SWFL, mobeious, woofercooker, kroid777, bubbagumper6, uglydimple12, dacheatham, canyouhearmatt
    traded with: funandgames, Jh8909, lincolntc690 OWES ME AN IPOD ADAPTER, MikeyF
    Feedback thread:
    http://www.caraudio.com/forum/showthread.php?t=443430
    94Mazda626's Avatar
    94Mazda626 is offline Senior VIP Member
    Nov 2007
    SK, Canada
    455
    Quote Originally Posted by boostNbeer View Post
    He's saying to drive the screws in from the back.
    Blue Fury's Avatar
    Blue Fury is offline Quagmire's Chin
    Aug 2008
    Fresno Area, Ca
    2,177
    Quote Originally Posted by RJesus View Post
    What other way is there? just the wrong way.
    glass the bolts in or carpet over the heads
    **********My build: 2 SSA Xcons, Sundown, Vifa, TB, Hertz, 880prs, etc.**********
    CA Refs: bought from: Jacka, bones22, civicman07, Zeuslicious, 90accordman, DesertDawg(<---EXCELLENT seller)
    Sold to: 97accordalpine, Jgyolai, brenTgrillzem, nicksredline, lantz, bagged97tacoma, Plottin4success, microhaxo
    ROE Refs: Bought from delvryboy, jnralp00, dcmcki, Mxman38, Excessive Amperage, GoinDef154, blackdragonx118, Assman.
    Currently For sale:
    10" RF Power HX2 with 6th order bandpass enclosure
  9. #9
    Upgrayedd's Avatar
    Upgrayedd is offline Double dose of the pimpin
    Oct 2009
    Ohio
    508
    bolt/screw from inside the pod through the speaker hole
  10. #10
    BradButlerNC's Avatar
    BradButlerNC is online now Be Swangin'
    Sep 2008
    North Carolina
    21
    2,996
    Either secure them through the back (if theyre MDF backed pods) or put screws/bolts from inside the pod, through the door panel, with nuts on the other side.
    Pioneer DEH-P5100ub
    Phoenix Gold RSD 5's
    Infinity 5022i's
    Phoenix Gold RSD300.4
    Audiopipe 1800-1D
    Audiopipe DMZ 15"s
    7.75cf @ 32hz
    2 batts under hood, C&D In Trunk, CS144 Alt
  11. #11
    kfx450r's Avatar
    kfx450r is offline CarAudio.com Elite
    Mar 2008
    Hammond, Louisiana
    718
    I dunno the colors your going with but I saw a beauty panel in someones ride yesterday that was wrapped in black suade with 2 visible screws and they were hardly noticable at all..and even noticed they didnt look bad as they were nice and flush and sorta blended in.
  12. #12
    Sep 2009
    Philly
    1,302
    Make a deep hole inside the panel, and put a screw in it securing it to a piece of MDF secured to the sheetmetal. Then put a cap inside the hole to make it flush with the rest of the panel, or fill the hole with something that can be taken out easily.
    Because eventually...for some reason or another...your going to have to take your door apart. And you don't want to turn a 15 minute task into a day long task that immobilizes your car
    Feedback thread:
  13. #13
    Nov 2009
    CA
    396
    I really dont see how you guys are trying to get me to tighten or screw from the inside of the door into the pod. its a big **** pod that covers half the door and theres no access to the inside of the door once its set in place.
  14. #14
    WrenchGuy's Avatar
    WrenchGuy is offline CarAudio.com Veteran
    Sep 2007
    East Tawas, MI
    2,048
    I've found it easy to mount where you can reach your arm through the speaker hole.
    I have big doors but a 9" hole too...lol Use your imagination there are plenty of ways to do it.
  15. #15
    Nov 2009
    CA
    396
    There wont be a speaker hole that goes into the door, the pods go over the existing door panel, and covers the entire thing, there will be no access to the inside of the door
+ Reply to Thread
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
