+ Reply to Thread
Page 5 of 11
FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 61 to 75 of 161
Thread: SEALED vs PORTED (basic info.)
  1. #61
    squeak9798's Avatar
    squeak9798 is offline Lovin life! Hallelujah!
    Jun 2004
    USA
    26,331
    Feedback Score: 0 reviews
    Re: SEALED vs PORTED (basic info.)
    Quote Originally Posted by dodgemyavenger
    sorry to rephraze the question that i asked.... usually when a subwoofer is mounted the rear of the sub, the magnet is inside of the box. if the subwoofer is instead mounted with the magnet on the outside of the box with the cone facing the inside is the performance of the subwoofer changed? by performance i mean sq, and frequencies and power handling. are certain subs not even designed to be mounted this way? if so where can i find this information i already checked the manufacturer's website.
    Performance is not changed. You can do it with any subwoofer.
    Just keep in mind that it will have an effect on the box size, however.
    I've found a great meaning to life and I've learned from my mistakes. I pray you all find it in your hearts to forgive me.
    WHERE'S YOUR GOD NOW?!?!?!?!
  2. #62
    Beat_Dominator's Avatar
    Beat_Dominator is offline Yea, thats Mecha Godzilla
    Mar 2005
    Phoenix Arizona
    27
    21,955
    Quote Originally Posted by jimmyjames1700
    Also, keep in mind that the real world vented enclosure will tune lower than predicted. That Kicker when loaded in an enclosure and begins having real power touch its VC, the box tuning will fall to somewhere near 34-35 Hz.
    When designing an enclosure for a super sub, say a Titanium or W7, you must design the box with tuning about 6-7 Hz higher than desired. If you ever modeled the 32 Hz tuned vented enclosure for the W7 on JL's website, you will see that it is tuned at 38 Hz.
    Wondering what evidence you have for this? Seems like that defeats the purpose of tuning a box at all, unless you are talking about cabin gains?
    Comming Spring 2009
    I make rear-loaded, double crabshell, isobaric enclosures.
  3. #63
    jimmyjames1700's Avatar
    jimmyjames1700 is offline Senior VIP Member
    Jan 2005
    duluth, mn
    226
    Quote Originally Posted by Beat_Dominator
    Follow the link below and check out the tuning freq of their own recommended 32Hz tuned box with. Mathematically it is designed to be tuned at around 38Hz.
    http://www.jlaudio.com/subwoofers/pdfs/12W7_MAN.pdf
    In fact all W7's, or other supersubs for that matter, need to be designed with box tuning that much higher (6-7Hz).
    When we first started designing and building custom vented boxes for the W7's we wondered why the tuning always ended up way lower than predicted. In fact, the first 32Hz vented box we designed and built for a customers 12W7 ended being tuned at 26 Hz! It definitely perked my curiousity.
    So a after a quick call to Hector at JL we learned that simple port formulas or programs like BassBox Pro cannot accurately predict what a sub/box combination will do once current starts flowing through a subs Voice Coil. Thats why the big shot's use programs like Leap which take into account many other factors. Basically T/S parameters and box calculators just get you into the ball park.
    I've seen it first hand. All vented sub enclosures designed with port formulas our say BassBox Pro will tune lower than predicted. Most will tune about 10%-15% lower than predicted, with the supersubs usually being significantly more.
    1999 Chevrolet Malibu
    Head Unit: Eclipse CD8053
    Front Stage: Diamond Audio D651a
    Front Amp: Eclipse PA5422
    Sub Amp: Eclipse DA7122
    Subwoofer: Eclipse SW9122
  4. #64
    singlesubsetup's Avatar
    singlesubsetup is offline Senior VIP Member
    Mar 2005
    seattle
    348
    Humm, to bring a thread back to life, (yea i used the search button :p) has completely made me rethink my considered box tuning.
    The sub I have has an Fs of 39
    Would building an inclosure with a tune of 38hz be appropriate?
    2 L7 10's in 6th order bp hifonics 1605d stock electrical. blue top under the hood, & kinetik capkiller pulled 141.4 @ 51hz on the tl
    Quote Originally Posted by theCybe
    I don't like them.
    Think of Hifonics the same way you'd think of Fruity Rings.
    Fruity Rings aren't Froot Loops.
    They're just the same shape.
    My 1 transaction as a seller HERE and HERE
  5. #65
    Decado's Avatar
    Decado is offline CarAudio.com Elite
    Jul 2005
    Minneapolis, MN
    1,121
    when i do calculations do i have to get them into the same units? For example, for Vd i have to do Sd x Xmax, and with the info i have it is 13.35 mm for Sd and 467.59 cm squared for the Xmax, do i have to put these both into mm? or cm? or what?
  6. #66
    EddieB is offline Junior Member
    Nov 2005
    norfolk,VA
    27
    15
    Ok I've read these posts ! I listen to rap music and R&B Whats sounds better sealed or ported and will making a completely sealed box damage my subs two 12"JL audio?
  7. #67
    squeak9798's Avatar
    Jun 2004
    USA
    26,331
    12" JL Audio tells us nothing. JL has had 25 different sub models over the years.
    Anyways....for rap you will generally want ported, assuming your subs will perform well in a ported enclsoure.
  8. #68
    Serialk1llr is offline Junior Member
    Jan 2006
    Hell
    18
    Hey, JL Audio 12w3v2 D4
    I've been reccomended to put it in a sealed box because I a) drive a scion tC (read cheap hatchback) with limited space, and b) listen to a _broad_ range of music. I believe JL reccomends 1-1.5 cu.ft for a sealed enclosure.
    ANY comments?
  9. #69
    jalverson's Avatar
    jalverson is offline my face got jacked!
    Nov 2005
    Williamston, MI
    27
    1,264
    sounds good mang
    Quote Originally Posted by iceteebone @ davidwm88_2
    if you gotta feel for it, might need a pair of tweezers
    Refs:
    Saywhat? -purchase plan
    M@njo -Sold Hifonics BX1500D
    DubbDesigns -web hosting
    Raven2201 -Built enclosure
    aDamJ -Sold cap<--tried to screw me after the fact do not deal with adamJ aim is apex isforlovers.
    Reggiewolf -Baught Jensen VM9410
    2lows10 -Built 2 enclosures
  10. #70
    funJeep is offline Junior Member
    Mar 2006
    Brewster, NY
    21
    I want to build a bandpass box 4th order for a DUAL XiNC110 woofer. It maxes out at 600 watts and has a 50-150 watt RMS range...the frequency range for it is around 30hz-220hz i believe. What I need to know is what frequency to tune the box I wanna build for rock/hard rock sound. This right now is the only thing holding me back once I figure that out I can use a design program and figure out the dimensions it should be and everything else. The dimensions I'm hoping to use are 15"W,13.5"H,12"D so if I use those dimensions what could I do to tune my box to a flatter frequency? I made a thread in this forum a while earlier but I'm desperate for a solution quickly so I can get started ASAP so some help would definatly be appreciated. Thanks to anyone who does reply to this with some useful info
    It's a Jeep thing....
    You don't understand.....
    Yeah, we understand
  11. #71
    SlammeD_SiR's Avatar
    SlammeD_SiR is offline Senior VIP Member
    Apr 2006
    Toronto, CAN
    258
    you guys make it seem like u wont have badass bass wit a sealed box????
    i got a type x alpine n i dunno much about boxes but i was thinking of going sealed. wha u guys think
    i listen to basically everything house techno dnb hiphop so i want it to be good overall
  12. #72
    bimma85's Avatar
    bimma85 is offline Can't be banned ;)
    Nov 2004
    midwest
    9,978
    Quote Originally Posted by SlammeD_SiR
    No way port that bish. Night and day
    REFS:JimJ, DBfan187, jimj, ology audio, excelerater, private pastry, kenny pollock, priosonnumber6, johnnyber, mattmmcs, vosschs, lax916, davidfre21, iceteebone, cd6551, vladd and others that I cant remember off the top of my head
    Quote Originally Posted by snb778
    I feel like when im bumpin once it gets dark....the street lights often go out. I was driving home the other night and like 3 street lights went out in like 15 minutes.
    Does this happen a lot to any of you??
    Also if you have had the twix ice cream......isnt it amazing!
    Quote Originally Posted by RumbleNTheTrunk
    damn. 8 10"s?........80" of cone area FTW!
  13. #73
    Apr 2006
    Toronto, CAN
    258
    y would u chose port tho??? personal pref??
    Quote Originally Posted by bimma85
  14. #74
    bimma85's Avatar
    Nov 2004
    midwest
    9,978
    Sealed...output= shitty. 1.75 net tuned to 32 and she sounds awesome and get pretty dam loud
  15. #75
    Apr 2006
    Toronto, CAN
    258
    the only problem is everyone i heard wit a ported sounded loud but shitttyyyyyy.. im sure if u do it proper it would be good i just dun want my sub sounding like a fart lmao
+ Reply to Thread
Page 5 of 11
Latest Posts Loading...
Loading...
Loading...
Loading...
Loading...
Thread Information
Users Browsing this Thread
There are currently 1 users browsing this thread. (0 members and 1 guests)
