Re: Thors 09 Build Log
nice idea with the bp.
I actually wouldn't try anything else without doing the proper calculations which I have failed to do every time correctly lmao. you will blow a coil, rather easily. Just saying man.
nice though
alt wise... mechman or ohiogen all the way. iraggi=bs along with a few others. they just won't put out what they say and they loose power output or fail with anything larger than 4awg on the post or excessive use.
also.. mechman and ohiogen usually come with very accurate birthsheets explaining everything from hotamps, total power at different temps and rpms etc. and quite a few other things.
nice stuff and very reliable.
one thing... if you have 1/0 from your alt post to the bat take it off and get the shortest 4awg you can put in it's place. I went from 15.2v steady to 15.6v steady. Unless your post is huge like on some alts over 300amps then the 1/0 is probably ruining your alt slowly.
Reason: forgot the I
The Systerrrm
Orion HCCA 15.2
AudioQue 2200D
3.7^3 @27HZ 3in. Kerfed Port (Help from Twisted Customs)
OhioGen 215amp H.O. Alt and BIG 3.
Kinetik bats and knu 1/0 etc. aka. JUNK
146 only legal score at dash
Honda Trunk Baby!
Btl score is too sad to post lol
(currently running a 15" BTL @ 40hz, I miss the massive Orion excursion :[ )
