Wire holders
CarAudio.com Regular
Will these work for a 3500 watt system to hold the cable down so they don't rattle? Or do I need some more stronger ones if so please suggest some
I use the plastic ones. They give a bit and won't interact should they manage to cut through the housing.
When you have a DSP unit, 4 amplifiers on an amplifier plate as well a 2nd battery, wire management becomes necessary if you want to keep everything organized. It also reduces the pull on the connections on the devices to almost zero.
Many people draw out their wire paths and drill holes on opposite sides and then use zip ties. I like those clamps, cause they're easy, look clean on wood or carpet and you can remove them and put them back should you need without having to pull the plate out.
Keeps things neat and tidy!
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
782
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
955
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
949
Charlotte
maylar
    Jun 2, 2024
    Jun 1, 2024
